Question about Apple iPod nano
IPOD NANO SONGS ARENT WORKING!!!
When i click songs on my ipod nano o play, they play a different song and dont allow me to play the other song. half my songs arent working now. What do i doo!?
Posted by mandy_moo04 on
Bee Santiago
  • 268 Answers
Test the songs that are not playing on the iPod in iTunes and see if the original file is still playable on iTunes if the song still plays re-sync your iPod could be when iTunes copied the song it must have failed or timed out, if that fails re-syncing try restoring you iPod Nano i have had this problem before and I just re-synced and it worked fine
Posted on Oct 18, 2011
Anonymous
    Problem Solver:
  • 7 Answers
Test the songs that are not playing on the iPod in iTunes and see if the original file is still playable on iTunes if the song still plays re-sync your iPod could be when iTunes copied the song it must have failed or timed out, if that fails re-syncing try restoring you iPod Nano i have had this problem before and I just re-synced and it worked fine!
Posted on Aug 27, 2009
Download to ipod
How Do I Download Songs Onto My iPod Nano?
IPod Nanos are portable multimedia players that allow you to playback songs and other content (e.g. video) no matter where you go. They come in a variety of memory sizes such as 4GB or 16GB (gigabytes) and work with iTunes to upload songs. ITunes is the iPod default management program which allows you to upload songs to its library, create playlists and sync music on your iPod quickly and easily. This simple process will have you jamming to your favorite songs in no time.
Downloading to an iPod Nano1Connect your iPod Nano to the computer using the USB cable. Launch iTunes if does not automatically launch. When you launch iTunes, it will display your iPod Nano on the left panel.
2Add music to your iTunes library. Click the "File" button on the top menu and click "Add to Library." Locate the song you want to upload to your player and click "Open" to load it to your program.
3Click the "+" button on the lower left panel to create a playlist. Type a name for the playlist and drag the uploaded file to it. To upload additional songs, repeat Step 2 and drag the uploaded additional songs to the created playlist.
4Drag the songs in the playlist up or down to select the order in which the songs will play.
5Sync your iPod Nano. Click the iPod icon on the left panel after importing songs and adding them to the created playlist. Click the "Music" tab and click "Sync music." Click "Select playlists, artists and genres" and select the playlist you created that contains the songs you want to upload. Click "Apply" to automatically sync and download the songs to your iPod Nano.
6Click the "Eject" button and disconnect your iPod from the computer.
Tips & Warnings
Click "Music Store" if you want to purchase a music file. Search for the song on the iTunes store and download it to the iTunes library.
Nov 23, 2011 | Apple iPod nano
Apple Ipod Nano does not play songs
It could be that the Format type is not supported. Like OGG isnt supported. I would look into using a different OS on it like Podzilla or RockBox
Apr 10, 2009 | Apple iPod nano
8GB ipod nano will not play songs
Try resynching your IPOD with Itunes on your computer then try to play again. If that does not work please respond and we can try another option. Also after you synch try the update option on Itunes as well that could fix any problems on the sofware side of your IPOD.
Sep 22, 2008 | Apple iPod MP3 Player
Cant playing full songs.....
when you installed itunes did you check the box where it asked you to automatically eject ipod or manually eject?
Jul 25, 2008 | Apple iPod nano
Removing songs from Ipod Nano using Winamp
Seems the playlist detais arent geting removed, only the songs.
So basicly you need to remove the deleted songs from the playlists ? you could probably do it on the ipod screen manually.
if my solution fixed your problem please give me a fixya rateing, becouse im trying to reach the guru status and its up to the voters(you) If I get there or not. I have over 700 solutions here and most of them are unrated!
So thanks alot for rateing!
Apr 03, 2008 | Apple iPod nano
Ipod - one at a time?
Absolutely!
Simply go into the "Settings" from the main menu and go into repeat. When the selection bar is over repeat, simply click the "Select" button to make it go to "Song". This will let that song repeat.
Sorry if this is wrong, but this works on my Video iPod and I don't believe that there is a difference between their settings.
Unfortunately I don't think there is a way to have it stop after the song unless it is the only song in the album. If this is the case, setting the repeat setting to "Off" will make the iPod play only that song by navigating to that album and selecting the only song there. NOTE THAT THIS DOES WORK!
Mar 22, 2008 | Apple iPod nano
Songs arent working need help
here is the iPod nano (3rd generation) Troubleshooting Assistant
http://www.apple.com/support/ipod/five_rs/nano3gen/
Try it, and drop me a line if you need more assistance!
Mar 14, 2008 | Apple iPod nano 3rd Generation
My ipod won't play songs I bought from itunes, and it won't let me download new ones.
Unfortunately, if you did not back up your music, the songs cannot be recovered. iTunes allows for one download of a song purchased.
Jun 07, 2007 | Apple iPod nano 2nd Generation MP3 Player
How can I add lyrics to iPod nano?
"iTunes 5: Adding lyrics to songs for iPod nano If you like to sing along with your tunes, iPod nano can display song lyrics right on its screen. Here's how to add lyrics to and view them on iPod nano. Entering lyrics In iTunes 5, select a favorite song. From the File menu, choose Get Info. Click Lyrics, then enter the words to the song in the text box. Click OK when finished. Copy the song to iPod nano. Viewing lyrics If you've entered song lyrics, you can view them at any time in iTunes 5. Just select the song, Get Info for the song, and then click Lyrics. If you want to view them on iPod nano, do this: On iPod nano, start playing any song to which you've added lyrics. Press the Center button repeatedly. The number of times depends on if you have artwork or not. Here's the order of things when you press the Center button: Play status > Scrubber > Album Art > Lyrics/Description > Rating If you don't have Album Art or Lyrics, then you'll just see the Rating Play status > Scrubber > Rating Lyrics should display correctly in most languages. If they do not, try removing any special characters in the Lyrics pane in iTunes, copy the song back to iPod nano, and try again. Note: Some types of files such as WAV and QuickTime files don't support lyrics, though you can convert WAV and QuickTime files into a format that would allow you to add lyrics such as AAC or MP3. "
Sep 28, 2005 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
efs_perpends
efs_perpends
Jean Sintulaire
Vish Iyer
Vish Iyer
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
