My camera tells me to format my new memory card. I try and it says that there is no memory card in my camera. What next?
SOURCE: Format Memory Card Error
The problem with the c350 is that it does not accept a memory card higher than 1GB! I found that out through the Kodak website and not in the User's Guide!
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
SOURCE: memory cards wont format, says card is full
Is the write protection enabled on the cards?
Which size having the cards?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmwar
SOURCE: Kodak EasyShare DX4530 Digital Camera Digital
If your using more than 2GB of SD card or if yous using the SDHC card it will not format the Memory card.
Try to used the recommended Memory card 2GB or 1GB SD card It will reformat your card. Too Much or too High SD card is not compatible on DX camera series
SOURCE: Z740 camera repeatedly formating memory card
Hi there , after formate if you face the same problem then, its look like the memory card life is end. He complete his total image serial number. For example:
Life time card capacity is DSC 00000 to DSC49999.
If he reach on end then he does not have any serioul no for further photos. In that case you need to replace the card. Thanks.
