20 Most Recent Kodak EasyShare C703 Digital Camera Questions & Answers
The C703 works with SD and MMC cards, 2GB and smaller. It will not work with higher-capacity SDHC cards such as your 4GB card.
Kodak EasyShare... • Answered on Apr 04, 2013
The C703 works with MMC and SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards such as your 4GB card.
Connected as external device with USB cable, or using some SD Card reader to connected directly at PC.
Kodak EasyShare... • Answered on Aug 17, 2012
Hi, The reason neither 4GB card will format is because that camera is only able to support, at most, a 2GB card. I'd suggest returning the 4GB card and getting another 2GB one.
Kodak EasyShare... • Answered on May 13, 2011
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Kodak EasyShare... • Answered on Sep 30, 2010
This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Kodak EasyShare... • Answered on Sep 24, 2010
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Kodak EasyShare... • Answered on Sep 02, 2010
Sand has undoubtedly gotten in the lens assembly. They recommend trying to spray compressed air to try to blow the sand out, or at least free up the gear mechanism. Sometimes the camera can be salvaged with this method. Sometimes you can push gently on the lens or pull, to try to free it up. Keep playing with it. If the gears are stripped, it will have to be serviced, in which case make sure you get an estimate, since the cost of repair can easily exceed the price of a new, name brand camera on sale.
Good luck. Here is a good website for lens error messages, but the things to try apply to your problem: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, they say about half the cameras with this problem can be fixed.
Kodak EasyShare... • Answered on Apr 20, 2010
Hi
I just had this problem with my D5000. I did a lot of troubleshooting to discover a Windows Code 19 error in device manager. To see whether this is your problem, go to Control Panel, select device manager. Your camera should be listed under cameras/imaging devices. If there is a yellow exclamation mark, disconnect your USB/transfer station. Using device manager uninstall the software drivers. Once uninstalled reconnect the camera and usb or transfer station. Drivers are on the camera. It should begin an automatic reinstall. When it says your hardware is successfully installed, you should be able to use the transfer station again. If not, and you got a disc with your station, then I suggest uninstalling all the software and reinstalling. Apparently in windows operating system, if the registry entry relating to that device is damaging, it will no longer recognise the device nor load the drivers. The only way to fix the registry is to uninstall the device and reinstall.
good luck
Kodak EasyShare... • Answered on Mar 02, 2010
Please try to upload new firmware: I doubt that it will solve the issue, but the alternative is a repair.
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9620/9621&product=EKN032784
Kodak EasyShare... • Answered on Feb 09, 2010
Check the setting where the pictures are being stored. It may be still storing to the internal memory.
Also check what resolution you are capturing your snaps. Although 22 pictures should not fill your memory but high resolution photos can take 5-6 MB /photo, so you can accomodate about 180-200 photos in 1GB. Try reducing the photo resolution, if you are not planning to print them.
Also, have you downloaded all the previous snaps from the card and deleted it from the 1GB card?
Kodak EasyShare... • Answered on Nov 06, 2009
You can connect your camera to your PC or laptop. then transfer all your pics to anyone of it. After that you can delete all the pics from the camera memory card. hence providing you with a full 1GB free space to click as many pics you want to.
Please respond back if this does not resolve your problem.
Have a great day.
You can use the KODAK EASYSHARE Software supplied with the camera to transfer the pictures to your computer.
You can save upto approx 333 pictures with 1 GB memory card.
hope i have interpreted this correctly.. It does not move out to full extent or soes not pull back all the way.. no matter.. try this kludge fix....
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 180 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate my help++++Thanks for using FIXYA
now 180 cameras fixed by this trick works on all brands and these types of cameras
Kodak EasyShare... • Answered on Oct 22, 2009
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Kodak EasyShare... • Answered on Aug 16, 2009
Sounds like a loose connection in the energy pack... this will require a professional to crack it open and re connection the loose connections...
Please rate advise.
Kodak EasyShare... • Answered on Jun 22, 2009
Have you tried a set of alkalines? They hold slightly more charge than rechargables. Also, your rechargables can go dead really, really fast. I use 'em but I always keep a set of alkalines handy, just 'cuz.
Kodak EasyShare... • Answered on Jun 11, 2009
Kodak EasyShare C703 Digital Camera Logo
34 questions posted
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
formate memory card
  • Cameras
