Using an adsl2 modem(calls itself a modem/router)TD-8816 that uses pppoe for the isp. I can access both independently. when I try to statically assign addresses to each I get all led lights the wan port on the router and they stay solid. the network portion is 192.168.1.x the router has a login section for pppoe but it doesn't sem to work anyway I cannot ping the modem while they are both connected.
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
SOURCE: How do I get rid of the router using an automatic private address which keeps disconnecting?
the router will give you a private address , that is the functionality of the router, the problem is not with your connection, try to upgrade the latest firmware inthe router and reconfig the router in a pppoe mode that will fix your problem..
SOURCE: My DSL Connection 1mb connection
you dont need to enter any ip adress just slect the auto detect ip.then conect you adsl modem with lan cable to wireless router.but it would be better if you use a switch between adsl modem and wireless router.
SOURCE: Couldn't get internet via Wirless Router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
With the steps that I given to you, it was mention earlier that u used the pppoe, dhcp, but not static ip, if your computer is directly connected to the adsl modem it works perfectly. this is the specs of ur modem:
Supporting 1483B bridging and routing function
Supporting DHCP server, NAT/NAPT , PAP/CHAP, IP Filter, Firewall, protocol block
Built-in PPPOE/PPPOA dialing..
you can try two option:
1. your modem is equip of supporting dhcp server, if u can access ur modem and set it to bridge mode so that the dhcp server wont conflict with the router bcoz the router has a dhcp capabilities as well.
2. you need to disable the dhcp of the router so that the modem will act as the server and will give ip address to your computers..
this 3rd option will be your last solution if both dont work..
try to check the ip address of the modem, if the the ip address of the modem is 192.168.1.1 and the ip address of the router is 192.168.1.1 as well, connect your computer directly to the router and change the 3rd octet of the ip address, ex-192.168.1.1 to 192.168.2.1 then your connecttion should be , the cable form the adsl model goes to the port 4 of the router and the router should be set on a dhcp settings..
I hope this solution will help you. good luck
if you have any querry pls feel free to get in touch.. good luck
SOURCE: Problem with RV042 linksys router
Ah Wan 2 doesnt like to receive a DHCP address you will have to get static Ip addresses
