We turn the power on and the heat-up light does not come on, nor does it heat water. Same when we turn on the Coffee switch. If we turn on the Steam switch, the water heats up (the heat-up light comes on, too). Any ideas what has happened?
SOURCE: Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
SOURCE: No hot water
Yes there is a small red breaker switch on the left side of the boiler tank. Unplug the unit first then remove the left side cover and just push down on the red breaker switch to reset it.
SOURCE: Rancilio Silvia not heating
Unplug machine and remove the top panel, check the thermostats on of them tripped reset and you should be back in business.
Testimonial: "Had the problem fixed in 5 minutes. Saved me a lot of inconvenience and (probably) money. Thanks for the solution."
SOURCE: the rancilio coffee machine failed to heat up no
Remove the top panel, and check the thermostats on the boiler there are 3 of them. One needs to be reset.
SOURCE: our rancillo silvia does not heat up water or make
Sounds like the heating element is fried, you will need to find a local person who understands basic electrical troubleshooting with a meter. Take the top off and have somebody meter voltage across the heating element electrodes if there is voltage ther,e but the machine is cold, your heating element positively absolutely has gone bye bye. We can repair this
WWW.DOLCEVITAESPRESSO.COM
