20 Most Recent
FrancisFrancis! X3 Espresso Machine Questions & Answers
I need a heater element
Hi
You might be able to get it to work but I have a Francis element that is made for the Francis. They are $20 + $10 shipping.
Looking for o-ring for model number 24FA espresso
This is a hard to find part, unless you contact FF directly.
However here's a quick and easy way to find replacement o-rings for anything:
Take the o-ring to a hardware store such as Ace, Home Depot, or Lowes. In the plumbing section they have bins of o-rings of all sizes. Buy the o-ring that matches your old one.
I have a Francis Francis X3 machine and would like
If you have an X3 Trio you are out of luck.
If you have the older model, you can buy 'ground coffee conversion kits' or you can use a ground coffee portafilter from an Ascaso Dream/Arc etc.
See: http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html
I need a Francis Francis x3 portafilter for ground coffee
If you have an X3 Trio - you are out of luck.
My francis francis x3 does not heat the water
Does the bottom light come on? The light is connected across the heating element and so if it is on the heating element is getting power. From looking at mine it looks like the bottom button for steam power bypasses the thermostat and uses the pressure switch to shut off the heating element. So if the light comes on when you press the steam switch but off when it isn't it is most likely your thermostat causing problems, if it never lights it is most likely the pressure switch. I do not claim to be an expert on the machine but from looking at mine that is what i would expect.
