Camera is working properly but screen is not showing anything. So let me know if my problem can be solved asap. Thanks
SOURCE: samsung digimax s 600
Connector problem internally- with the battery out try genrtle squeezing of the casing near bottom of the screen - this may get the connector back in Contact Samsung for further advice
SOURCE: What is the part number for the lcd screen on a samsung s850
If your camera costs less than $350.00, parts plus shipment will hit you over $90.00.
Oh, they come with no warranty.
Best just use the camera like a film camera. Shoot and download into computer to view or delete photos. This step is slower, but still cheaper than repairing or using film camera.
Alexander
[email protected]
SOURCE: Hi, My batteries died I've replaced them with
Hello.
Here are the things you can try:
Make sure that the batteries are inserted properly, with the + and - in the correct positions. Also, make sure that the battery cover is secured tightly. Check the voltage of new batteries you installed and compare it with the old batteries. Try another set of new batteries.
If that doesn't solve your problem, please update me.
SOURCE: Hi. Got an Samsung PL55
Hello
Thank you for using FIXYA!!!
This
is a suggestion. If you do not feel comfortable trying it, you will need to take
the unit to your nearest service centre. Feel free to let me know if you
need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
"Resolutions available for the HDMI output are 480p, 720p,1080i/1080p. See page 27 for the resolution setting.
This product operates in Interlace scan mode 480i for component/composite output.
After making the video connection, set the Video input source on your TV to match the corresponding Video output (HDMI, Component or Composite) on your product.
Turn this product on first before you set the video input source on your TV. See your TV owner's manual for more information on how to select the TV's Video Input source."
What does your unidentified TV manual say about the message?
Hello, you need to connect the sound output and video output of the TV. To the entry of sound and video of the amplifier. Should match the cable type, the type of connection to existing instruments. Usually connections are RCA connections or SCARET. Once you have connected, you need to choose the entrances of the amplifier switch, according to entries you've used. What remains is only to increase the volume. Good luck
