Replaced batteries and got a new sd card so I could just leave camera up and switch cards, but now camera will not let me enter password with new sd card in it.
SOURCE: SD Card size
I put a cheap PNY Wal mart 2G in mine and it worked fine, no errors, yet anyway. I did not know the manual stated up to 1G until I got home with it.
SOURCE: Cant get my SD card that came with my bushnell
SD cards have a slide switch along one edge. The position nearest the contacts unlocks the card. If the switch is already there, try sliding it fully in the opposite direction and then back.
Does that help?
SOURCE: 11-9200 bushnell trail cam.
Sounds like you didn't use the "safely remove hardware" function when you took the card out of your computer.
SOURCE: my bushnell trail sentry wont
Hi grahamb457,
For you to save the pictures on the SD card, you should first select it as defauly memory from the setup options.
Once you select it as default memory you will be able to see the change in the number of photographs you can take on the LCD screen.
I would recommend you to restart your phone once you change this settings.
Hope this helps ...:)
