20 Most Recent Bushnell 119435c Digital Camera Questions & Answers
The PIR setting on my
Hello. The PIR acronym stands for passive infrared. it is the motion detector.
Every time an "event" is detected, the display will indicate "Plr", "EVNT", "rECd" in turn, and the event is recorded on the SD card as a new line in a text file, including the date and time of the event. As long as events are being detected, a new still photo or movie clip (as set in the menu) will be recorded every 30 seconds, indicated on the display by "Plr", "SnAP", then "SAVE".
The sensor that triggers the trail camera is Passive Infra Red, or PIR. Infrared energy is essentially heat energy. The PIR detector operates by sensing a change in the infrared level in its detection zone. This zone is a cone in the center 10 degrees of the camera's field of view. The camera establishes an average long-term infrared level. When this level increased suddenly the PIR detector signals the camera to record a picture and/or an event. Because of this effect, the PIR detector will be more sensitive at night, when the average temperature is lower.
You can use the red LED indicator on the front of the camera to confirm the detection zone.When PIR is sensed, this "PIR detected" indicator will light. The camera's field of view is a 45 degree cone, centered on the PIR detection zone.
the PIR is strongly sensitive to ambient temperature. The greater
the temperature difference between the environment and your subject, the
farther the possible sensing distance. The average sensing distance is about
45 ft.
Check the "Sensor Level" (PIR sensitivity) parameter setting.
For warm environmental conditions, set the Sensor Level to "Higher number"
and for cold weather use, set the sensor for "Lower number". If the temperature is between 56 and 75 degrees farenheit start out with a setting of 3 and experiment to see if it is the best setting under all of your climatic conditions.
Joe
4 thumbs up please.
11/1/2010 7:41:44 PM • Bushnell 119435c... • Answered on Nov 01, 2010
Bushnell trail sentry just has dashes wont display anything else
Hey I have the same one when I hit the power button the display only shows 4 dashes I held the the enter button but all it does is turn the display off. Any help would be much appreciated
9/14/2020 5:11:33 AM • Bushnell Cameras • Answered on Sep 14, 2020
How to change a forgotten password on a bushnell hunting camera
notify bushnell support for assistance
5/5/2018 8:29:48 PM • Bushnell Cameras • Answered on May 05, 2018
RI have a bushnell trail
Download the firmware from their site onto a newly formatted sd card...and it should sort this out.
11/21/2017 12:15:53 AM • Bushnell Cameras • Answered on Nov 21, 2017
I have something loose in my one lens of my Bushnell binoculars. Can this be fixed.
Contact the manufacturer, or take it to a service centre.
8/4/2017 9:07:07 AM • Bushnell Cameras • Answered on Aug 04, 2017
I need a manual for a bushnell trail camera. Sn: 9327 19141
Serial numbers are no help, need the model number.
7/27/2017 10:02:18 PM • Bushnell Cameras • Answered on Jul 27, 2017
Need information and Instruction Manual for a Vintage Bushnell 300mm camera lens
This is not a zoom lens, it is a fixed focal length of 300mm telephoto, so the focus ring will not slide back and forth, merely rotate. It is also manual focus. If you google it, you may find a manual, but doubtful - best bet is to get a book on basic photography and read up on telephoto lenses there.Update - allegedly made by Tokina, so should be a reasonable lens.
4/1/2017 10:24:30 AM • Bushnell Cameras • Answered on Apr 01, 2017
Bushnell 119435c Digital Camera Logo
6 questions posted
Top Bushnell Cameras Experts
Marvin
Marvin
john h
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
View Most Popular
Bushnell Cameras
  • Bushnell Cameras
Most Popular Question
pir setting
  • Cameras
