It is now saying Insert Boot Media in selected boot device? that is greek to me
Sounds like the boot file is corrupted or deleted. it may be fixed by shop with the appropriate tools. the file must be replaced and most people do not have access. otherwise you could restore the 'whole' system from backups if you have them or if you created a repair disk
that may work. restoring takes time but its cheaper than a shop doing it or fixing it. good luck
SOURCE: When I turn the computer on, I get the following
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Testimonial: "Thanks- I chated with Gateway and NO help. Not even what to try."
SOURCE: GETTING ERROR: REBOOT AND SELECT PROPER BOOT
its not detecting your HDD. on boot enter BIOS & check whether your HDD is being detected by the MB. IF not(most possible) then check the power & data cables to your HDD, Check your SMPS too, if SMPS OK then your HDD is corrupted. GET new HDD
Firt thing you can check is wthr your harddrive is detected or not. to do that you have to enter to the BIOS,To Enter BIOS you have to press DELET or F1 or F2 key(Mostly DELET). Now inside the BIOS in main menu check if your hard drive is showing or not. If it is showing there then you try to find out boot sequence, option after getting the boot sequence optuon check if the first device is other then hard drive.
if your harddrive is detected and your first boot device is also set to HARD drive then it might that your Operating system is Crash, in that case you need to re install the OS.
Now if you can see your hardrive in your BIOS then you can open the case( remember to unplug all the cable, Power, VGA, KEYboar ...etc) and try to inter change the harddrive cable connting cable, i mean just try to chage the port of the cable to other one and try switch on your computer ... if still you find the same problem then try changing new cable. ....well if still you have the same problem then i am afraid that you might need to replace the hard drive with new one.
Sorry for the Bad Englsih. Hope the above steps will work for you and you understood what i tried to say.
Cheers:)
SOURCE: reboot and select proper boot device or insert boot media in selected boot device and press a key w7
Give this a try you probably have a mbr virus..
Download The following iso listed
below. It is the latest version of the Kaspersky rescue disk. You need
to burn it to a CD with a program like Imgburn (Which is also FREE like
the iso file). Then you need to boot from the CD and run the scanner.
It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
