Hi- My name is Shannon and I am with Suddenlink. If you are still having trouble programing your remote, you can find all the codes on our Suddenlink Support site, here: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx. Thanks!
SOURCE: charter cable box
Could not find box on list but here is your product manual:
http://www.ofausa.com/remote_manual/CTGAE3P%203021%20anual%20booklet.pdf
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code in the following boxes:
SOURCE: universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you
have one the "magic" button for three seconds, a light should then
flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: Remote Control Code for Motorola Cable Box
I have a Motorola cable box and used code # 051. Works great. Can't find a code for DIGISTAR tv though. If anyone has one, shoot it to me at [email protected].
SOURCE: Remote Codes for Motorola Cable Box DCT700/US
I have run into this problem with my Sharp Aquos as well. This is not necessarily a code problem but an interference problem.
If you take your hand or a thick book and sort of make a hood over the
area of the sensor on the cable box and place the remote right up close
to the sensor this will help let you know if the remote and the box are working
with the code. Also might try turning off the TV or unplug the TV to
test and make sure the remote will turn on the box.
Next thing after you determine this is how to block the interference
and be able to use your remote. What we did is placed the Wii on top of the box over the area of the sensor and this seems to have done pretty good.
Good Luck ....
Hi rydenkd- My name is Shannon and I am with Suddenlink. Please visit our self-help site to troubleshoot and reprogram your remote here: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx. If you still run into difficulty, please feel free to contact me directly at shannon-AT-suddenlink-DOT-com. Thanks!
Hi- My name is Shannon and I am with Suddenlink. If you are still having trouble programming your remote please visit our self-help site at http://help.suddenlink.com/Television/Pages/RemoteControls.aspx. You can choose the type of remote you have and it will pull up a list of usable codes. Thanks!
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1) From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
