I cannot connect to the network it keeps telling me that the pc or driver needs to be updated witch i am not sure why. please help me i do not won't to be paying for something that i cannot use?
First is there a security code to connect to your wireless access point? This is YOUR home wireless? Is your wireless adapter enabled, and working properly on the laptop? Reboot the wireless access point by removing th AC plug and wait 30 seconds,plug in, wait for the device to self-test. Cold-start your laptop, unplug. remove battery, plug in, reboot. If that fails go to IBM/ Lonovo website and update driver for wireless adapter.And all other deivers as needed.
SOURCE: IBM thinkpad 2647 T21 LAN Card Driver files needed...
if you are using the internal LAN card to connect to the cable modem, no additional drivers will be needed. However, you would need to configure TCP/IP settings to use a DHCP server to automatically configure the IP address. you would also need to check whether or not you have the right CAT-5 cable. you might need to buy a crossover cable.
hope this helps
SOURCE: Wireless network connection on IBM Thinkpad
Ok when looking at your question i became very currious as to the answer myself so i did a litttle research and i think maybe the info on this page here: http://www.eggheadcafe.com/software/aspnet/33307589/certificate-required-to-c.aspx
could be of some use to you . even though the link describes a diferent network adapter the information there is about the same exact error on a router of the same type
I hope this information helps ... if it does not then let me know and i will find some more answers since i used to have the exact same laptop that you have now R40
SOURCE: ibm thinkpad t42 switch for wireless network
The T42 has a bulit-in wireless network adapter and a LAN network card. T42s most likely have an Intel wireless card or less likely a Cisco wireless card.
Your wireless network adapter may have been disabled in the BIOS
and/or
The drivers for the wireless network controller has not been installed.
To check the network adapter go to the Control Panel, Click on System, click on Hardware Tab then Device Manager. Then scroll down and click on Network adapters. If you don't see your network controller or you see a yellow ? against Other devices for the Network controller. Then either it has been disabled and/or the driver was not installed.
To get the driver for the network controller you need to dowload it from the IBM/Lenovo WEB site their support/download page from a computer that has Internet access. Make sure you select your laptop model and the driver for your Windows version.
Install the driver and you then need to configure the wireless adapter to suit your wireless router settings before you can access the Internet.
SOURCE: IBM ThinkPad T60. No sound & internal wireless modem is dead
Sounds like you need to reinstall the sound driver, the should be located on your computer, or you can download then from IBM's website
XP drivers: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-62855
Vista: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-67218
Hope this helps, if so please rate accordingly.
Thanks,
David
SOURCE: Drivers for Network controller, Video controller, Wireless
Please visit IBM website and you can see the driver files in that site
