My sons account works fine. I was without my computer for 2 months, and did not login to my account, but my son did login to his. We have the same password, as well. Now I cant acsess my account, and I use to be able to. What can I do?
If your Facebook profile is still unavailable after many days, then send an email to [email protected] and explain them the issue. http://www.facebook.com/help/?page=121467344601554 Once you send them an email, your account will be available again soon.
[email protected],
hope this helps
SOURCE: i cant sign in to facebook i can put my email then
if you are using internet explorer then click on "start/control panel/internet option" on the advance tab click on "reset" and click on apply and ok.
it should work.
best of luck
SOURCE: i cant login to facebook account
Ensure you typed in your correct username and password, then if it denies you the access, then it will require you to fill in some answers to some security check questions, answer them correctly and it will log in.
If it says incorrect password or username, try to access it from any that is sent to your inbox, then if it does not access it still, then it is either facebook is experiencing a temporary problem or that your password have been changed or your account have been tampered with.
Take care and good luck.
SOURCE: i cant remember my administrator password, is there a way to reset or undo it
Restart your computer, when you see your computer manufacturs logo pop up, start pressing the F8 button on your keyboard. Some options will pop up onn your screen, useing the up and down arrows on your keyboard, scroll down to the option "safemode with networking" and press enter. After a few minutes your login screen should pop up with two admin. accounts, one password protected, one not, click on the open admin account, do not be alarmed by the way everything looks, your in safe mode. From in here, go to control panel/user accounts, select yours and choose the "remove password" option. Your done. Restart your computer, select your account from the login screen - and you will be let in.
SOURCE: RETURN COMPUTER TO FACTORY SETTINGS WITHOUT PARENTAL CONTROL PASSWORD
http://www.ehow.com/how_6547558_restore-dell-latitude-factory-settings.html
This may work for you. Click the link. Follow the instructions. If you have a recovery partition this should work.
