Cars & Trucks Logo
Anonymous Posted on Oct 16, 2012
Symptoms for a faulty neutral safety switch
I am looking for the symptoms of a faulty neutral safety switch on a 1995 jeep wrangler....just want to be sure thats the problem before I replace it.
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
  • Posted on Oct 16, 2012
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29060772
Points
266281
No start (engine doesn't crank with starter motor) in neutral and park position, one or both
Jonah Oneal
Level 3:
  • Cars & Trucks Master 14,092 Answers
Jonah Oneal
Level 3:
Answers
14092
Questions
0
Helped
7242175
Points
44533
Sign neutral switch is bad. no back up lights,vechicle wont start.when you apply brakes cant get vechicle out of park. both neutral switch and brake transmission shift solenoid. if you have problems getting vechicle out of park check the brake transmission shift interlock solenoid fuse first before assuming neutral safety switch is bad.
  • Marvin
    Marvin Oct 16, 2012
    The brake light circuit is what power up the park lock system not the range switch
  • Jonah Oneal Oct 17, 2012
    yep when you apply brakes it power up park shift solenoid. neutral switch on a different circuit. i had problem with neutral switch my back up lights did not work some times i could not get car to start. i told my friend to check make sure the shift lock solenoid fuse not blowed if he is having problem getting out of park. but a faulty neutral switch will cause no start and no back up lights.
5 Related Answers
Anonymous
  • 6982 Answers
  • Posted on Jun 17, 2009
SOURCE: replace 1995 jeep wrangler catalytic converter
If it has flanges on both ends, just unbolt it and replace. If it has welded pipes you will need to cut it off and use adapter sleeves and clamps. Really not rocket science...at worst, you may need to remove the hangars on the rear portion of the system to get enough room to install.
Anonymous
  • Posted on May 25, 2009
SOURCE: 2004 Jeep Grand Chrokee Neutral Safety Switch Location
The switch is on the transmission..It is usually a dealer item but you can get one from Rockauto.com for about 1/4 of what the dealers charge.
Anonymous
  • 1129 Answers
  • Posted on Jul 14, 2009
SOURCE: neutral safety switch
It is located on the side of the transmission, follow the shift cable down to it you will recognize it because it has a electrical wire comming off it and either a shift lever or shift cable going to it.
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Sep 18, 2009
SOURCE: Looking for the neutral safety switch
Neutral Safety/Back-up Light Switch
This is a combination switch which controls both Neutral Safety and Back-up lamp circuits.
C6 Transmission
C6 neutral start switch
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle on jackstands.
  3. Remove the downshift linkage rod return spring at the low-reverse servo cover.
  4. Coat the outer lever attaching nut with penetrating oil. Remove the nut and lever.
  5. Remove the 2 switch attaching bolts, disconnect the wiring at the connectors and remove the switch.
  6. Installation is the reverse of removal. Adjust the switch and tighten the bolts to 55-75 inch lbs. (6.2-8.5 Nm).
  7. Remove the jackstands and lower the vehicle.
  8. Connect the negative battery cable.
AOD Transmission
Removing the AOD neutral start switch
  3. Disconnect the wiring from the switch.
  4. Using a deep socket, unscrew the switch.
  5. Installation is the reverse of removal. Tighten the switch to 10 ft. lbs. (14 Nm).
  6. Remove the jackstands and lower the vehicle.
  7. Connect the negative battery cable.
4R70W Transmission
Removing the Manual Lever Position (MLP) sensor
As of 1994, the neutral safety switch is referred to as a Manual Lever Position Sensor (MLP).
  3. Disengage the harness connector from the MLP sensor.
  4. Remove the 2 sensor attaching bolts and remove the sensor.
To install:
  1. Install the MLP sensor and install retaining bolts. Do not tighten, the sensor requires adjustment.
  2. Adjust the MLP sensor then tighten attaching screws to 80-100 inch lbs. (9-11 Nm).
  3. Remove the jackstands and lower the vehicle.
  4. Connect the negative battery cable.
ADJUSTMENT
C6 Transmission
  1. Hold the steering column transmission selector lever against the Neutral stop.
  2. Move the sliding block assembly on the neutral switch to the Neutral position and insert a 0.091 in. (2.3mm) gauge pin in the alignment hole on the terminal side of the switch.
  3. Move the switch assembly housing so that the sliding block contacts the actuating pin lever. Secure the switch to the outer tube of the steering column and remove the gauge pin.
  4. Check the operation of the switch. The engine should only start in Neutral and Park .
4R70W Transmission
Adjusting the MLP sensor
Park is the last detent when the manual control lever is full forward. Return 2 detents toward the output shaft for Neutral.
  1. Position the manual control lever in Neutral .
  2. Insert Gear Position Sensor Adjuster tool T93P-700 10-A or equivalent, into the slots.
  3. Align all 3 slots on the MLP sensor with 3 tabs on the tool.
  4. Tighten the attaching screws to 80-100 inch lbs. (9-11 Nm).
I hope help you. Good luck (rated this help).
Dog Spalls
  • 16 Answers
  • Posted on Nov 16, 2009
SOURCE: Where is the neutral safety switch locayed at on
Where they all are on Toyotas - on the trans, mounted under the selector arm (the one that moves when you change gears.)
Where is the neutral safety switch located on my 2008 Jeep wrangler?
Sounds like you're starting at the expensive end and working backwards! First, check your battery, make sure it has a good charge. Second step is the starter solenoid. Some designs have external solenoids, some are internal. Third is the starter itself. Once you are sure all that stuff is good, THEN it's time to start looking for the neutral safety switch.
The check engine light is meaningless when the engine is not running.
How to replace a neutral safety switch on a 2006 jeep wrangler.
so what make you think its bad.
manual or automatic trans.
mines a stick. so....
on the a/t slush box, its on the left side
go to jeep.com see your car parts.
see your trans
see your TRS switch. on side, bingo>?
Jeep wrangler 2.5 standerd turns over has fuel but no spark checked all relays and crank sensor computer is shuting down asd relay as soon as key is on. what does pcm look for when asd relay is not...
Is it an automatic transmission?
Have you try to start the Wrangler in Neutral.
On automatic transmission there is a neural safety switch.
When it's not send the correct gate position signal (P R N D... ) to the ECU not energize import relay like ASD.
Check for loose linkage to the transmission. + lube linkage with white Lithium grease spray.
Check for loose wiring to the neutral safety switch.
I have a 1995 jeep wrangler and the reverse lights do not work
First thing I would do if you haven't already is replace the bulbs. You may want to have one bulb out and see if anything happens with a multimeter when it's in reverse. You most likely will need two people for this job. Most likely I would guess either a fuse, or your neutral safety switch is to blame. The fuse would most likely be the turn/bu fuse. The neutral safety switch is about a 20$ part and fairly easy to change.
Thanks,
Lee
1helpful
1helpful
1994 jeep wrangler 6 cyl 5 spd no start
have u ck out the ignition switch [not the key & tumblers],, or the neutral safety switch to see if u have power ,,also seen broken wire at solenoid on starter too,,hope it helped,,
I have a 1998 jeep wrangler with no power to starter from key switch
Check for power on the "out" side of the switch, check starter relay in power distribution center and check neutral safety switch (auto) clutch switch (stick) Likely the problem is with one of these items.
Clutch pedal, starter, ignition... where is the safety relay for the clutch pedal depression to allow start? 1994 Jeep YJ 4.0 this has happened twice
If you find the switch, you can temporarily jump across it, 'till you get a new one. When you go to buy it you are looking for a clutch switch.
Neutral switches are found on automatic trans vehicles. If you jump it out, be VERY careful to make sure you start in neutral with the clutch depressed as without the switch, it will start in any gear even with the clutch engaged.
Neutral safety switch
I would recommend going to the autozone.com website and registering the vehicle. It doesn't cost anything and will give you access to an online repair manual for the vehicle. The steps for replacing the neutral safety switch can be found there. (I checked). Hope this helped and best wishes.
Where is the neutral safety switch in a 2002 Jeep Wrangler with automatic transmission?
should be part of the prndl switch which is on the trans just behind where the linkage is fastened
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
