SOURCE: SONY 57' HDTV color projection TV, red color dominance on-screen
these tv's have a problem with bad crt's you could try to replace the red but a better choice would be all three
SOURCE: Hitachi projection 57 inch tv screen just went black, but still have sound
Research at www.HitachiServiceUSA.com ........T.
SOURCE: My Hitachi 57 inch HDTV 57F500 model has a convergence problem
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
SOURCE: 57 hitachi ultravsion rear proj hdtv :ps3 hdmi issues
TRY ON THE DISPLAY PS3 SETINGS TO NOT LET THE HDMI DO AUTOMATIC,,CHECK OFF A FEW ,,LIKE TRY JUST DION IT CUSTOM,,CHECK 480P,,AND 1080I,,,NOT 720P OR 1080P,,TRY THAT AND IF YOUR TV IS A 1080P,,JUST CHECK THAT,,OR IF ITS A 1080I,,JUST THAT
