2004 Volkswagen Passat Logo
Posted on Dec 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GEAR PROBLEM please help me..my name is jay from nigeria and i have a volks passat 2004,1.8 engine.the car jerks when the speedometer gets to 40 whenever am driving and same applies when i change my gear to P or R. NEED URGENT ASSISTANCE
ricky horwood
Level 2:
Scholar:
  • Expert 128 Answers
  • Posted on Dec 28, 2008
ricky horwood
Expert
Level 2:
Scholar:
Answers
128
Questions
0
Helped
70800
Points
230
Hi there
you may need a new torque lock up
the torque lock up makes the car changes gears smooth and easy
this may be your problem
hope this helps
ricko
2004 volks passat with smell of gas, check engine light on, slow acceleration what could this be
if you can get it on a lift id check from your tank and follow all the lines up to your block, checking for leaks. does it smell like burnt gas or raw liquid?
2answers
Sudden jerking wen my acura mdx 2004 model want to change from gear one to gear two.
Your best bet is to get your transmission check sound like it freezing up before it gets worse.good luck.
1helpful
Starts in a wrong gear (4th gear) and jerks before it go
Run fault codes and look for a faulty TCM unit. THE TCM will also put on the engine light and affect the speedometer operation . Running the fault codes will also identify the sensor associated with the ABS unit.. Seeing as to how you have just bought the car (possibly from a corner used car dealer) I would advise a pressure test done on the transmission to check for the condition of the transmission and have an oil change and the bands and clutch packs adjusted
TAKE THE CAR BACK!!!IT HAS MAJOR ISSUES THAT NEED TO BE SOLVED!!!
Tiptronic gearbox
You need the powertrain control module/processor checked for fault codes
2answers
2helpful
How do you reset the service computer display on passat
volks wagon passat engine computer reboot where to plug the device into
Lights on dashboard foot
It means you must have your foot on the brake pedal in order to shift gears.
1helpful
3answers
Auto Gear problem of VW Passat
I think that the automatic transmission fluid is at a low level?
When its cold the oil will be still stuck to gears, but after is warms it flows off.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
