Force it to stay turned off, charge it, and try again? Remove the battery, and try again? Remove the SD card, turn it on, if it continues, put it back and try again?
I have had to restart my Verizon home style phone several times, because of the same thing. I just turn it off for a few seconds and restart it. Then call out to my cell phone and it works fine until it does it again.
mY Dear: First: restore your Phone Settings IF Restart problem not Solved So Secend Option: Please Format Your Phone we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure. *#7370# or *#7780# Default security code is 12345 release some memory then it will b opened your phone or memory card get attack by virus. pls do a format phone and memory card. If Problem Not Solved So Very Best Solution: flash new software install in the phone problem will solved quickly
i had the same problem, but not the same phone. what i did was take out the battery for about 24 hours. when i put it back the next day it worked fine. hope it works out for you. :)
if the phone restart..try removing your memory card if theres any. then turn it on..if this solves your problem then your memory card has a virus try formatting it..
