20 Most Recent HTC Aria Cell Phone Questions & Answers
no root !
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages on Android without root your phone.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
Facebook Homepage:https://www.facebook.com/GT-Recovery-for-Windows-527139864132104/
Google+:https://plus.google.com/communities/109657948177651590858
HTC Aria Cell... | Answered on Dec 16, 2019
you can try by updating your phone
if the problem remains try factory settings(back up your data)
Mother board has to be replaced from an unauthorized service center.
HTC Aria Cell... | Answered on Dec 24, 2017
To Unlock the HTC Aria Phone Reach here
Wickedunlock.com buy the Unlock code and Unlock it step by step.....
HTC Aria Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HTC Aria mobile phones. If you enter over a certain amount of wrong unlock codes on your HTC Aria mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your HTC Aria with a Not ACCEPTED SIM Card.
2. If your HTC Aria asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Aria will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Aria is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your HTC Aria is locked to.
HTC Aria Cell... | Answered on Jul 07, 2015
APN SETTINGS OR LOCATION
HTC Aria Cell... | Answered on Mar 07, 2015
Better get it done from an authorised service center. There are lot of ribbon cables, which could get damaged due to a slight negligence.
HTC Aria Cell... | Answered on Oct 25, 2014
It means your phone is network locked. You can simply unlock it by your phone unique unlock code. Get it from http://www.fastgsm.com/en/htc/aria/unlock-code/network-unlock
HTC Aria Cell... | Answered on Feb 10, 2014
Check that you don't have pocket lint etc stuck inside the audio socket. Turn off the phone and use a paper clip to see if you can hook anything out. If you can't push the plug all the way in, it can cause the problem you describe. Otherwise take a look at http://www.urheadphones.net/ReplaceEarBuds
HTC Aria Cell... | Answered on Apr 11, 2013
If your phone displays the 'SIM unlock code' then your phone is currently locked to particular network. You need to unlock to use it with other network.
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
HTC Aria Cell... | Answered on Mar 01, 2013
Unlock Cell Phones
Your cell phone may be locked to a particular cell phone provider and in this case it needs to be unlocked to use with a different cell phone service provider. To get the security code/restriction code to unlock the cell phone from the current cell phone provider so you can use the SIM card with a different phone provider, Please click on this link and follow my instructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then these WEB sites it provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw http://www.mobileunlocksolutions.com/ http://www.superunlockcodes.com http://unlockcellphonecode.com/
HTC Aria Cell... | Answered on Jan 19, 2013
Do a factory reset, but make sure you update with Back Up Assistant first, because it will reset your phone to the way it was when you pulled it out of the box. When you reset it you'll have to reinstall some of your apps and resign into all of your email and social network accounts. Also, when it asks you to confirm you want to do it, make sure the box that says "reset SD card" is not checked. Or just to be on the safe side; turn off your phone and pull out your SD card first.
HTC Aria Cell... | Answered on Oct 22, 2012
http://www.iphonerepair.com/htc-aria-glass-replacement/
You can get it repaired by sending it to them and they'll send it back fixed. It's pretty costly though.
HTC Aria Cell... | Answered on Oct 10, 2012
HTC Aria Cell... | Answered on Sep 27, 2012
Force it to stay turned off, charge it, and try again?
Remove the battery, and try again?
Remove the SD card, turn it on, if it continues, put it back and try again?
HTC Aria Cell... | Answered on Sep 20, 2012
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
HTC Aria Cell... | Answered on Jul 26, 2012
HTC Aria Cell Phone Logo
125 questions posted
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
HTC Cell Phones
  • HTC Cell Phones
Most Popular Question
need unlock htc aria
  • Cell Phones
