LAPTOP JUST DIED EVEN THOUGH THERE WAS POWER IN BATTERY
SOURCE: speaker volume like small baby
To fix the volume control re-install the drivers of the laptop and in the right lower corner you will see a speaker like symbol where you can control the volume. Increse the volume from there.
Thanks
Jimmy
SOURCE: restore factory settings for my samsung r519 laptop win7
system restore can do this for you if windows does work
if not recovery disc are sold on line through ebay and other web sites
SOURCE: my samsung r519 laptops battery will not charge
Please refer to the following article for a full explanation of how to diagnose & troubleshoot this problem:
http://www.fixya.com/support/r6416948-troubleshooting_laptop_power_failures
SOURCE: why wont my samsung np- r519 switch on
The power supply unit might be bad cannot specifically isolate the problem you may have to replace the prong pin on the mother board where the power unit plugs in this is a common problem with lap tops and because over time the solder gets weak and brittle and breaks a solder point this could also be an issue. I suggest that you take this in and have it looked at by a professional. Have them check the power supply unit and the board pin. Thanks for using FixYa! John
SOURCE: I have Samsung NP-R505H laptop. My laptop won't
You say it isn't charging, but will it run off of AC power? If it isn't getting *ANY* AC power, then it might be the female end of the power jack on the laptop. If it will run on AC, the culprit is likely to be a battery that needs replaced.
