Which position should switch on/off be in for charging off is green & on is red,how long been on 3hrs no change to say.
SOURCE: I have the rechargeable battery
If you remove the rechargable battery pack and put regular batteries back in, are you still having the same problem? If so, I would recommend returning the rechargable unit and replacing it.
For what it is worth, I've been using my Wii Fit board for nearly a month on 4 alkaline batteries and have not had any problems.
I recommend rechargeable NiMH batteries with a 15-minute quick charger. Always have four more batteries than you need in your machine, ie: if you have a Wii Fit, a Nyko Wireless Sensor Bar, and two Wiimotes, then you should have 16 batteries total (4 + 4 + 2 + 2 + 4 spare).
SOURCE: cant charge battery pack for wii fit balance board
You may want to send an email to [email protected]. In the meantime, try keeping it plugged into the USB port for at least an hour, or perhaps overnight. See if the light stops flashing and stays on. Then try plugging it back into the Wii Fit unit.
My personal suggestion is to return the charger and battery and buy a 15-minute charger and four more NiMH AA batteries than you need for all of your accessories. Not only are AA batteries compatible with all your accessories, but you won't be out a gizmo while it's needing to be charged.
SOURCE: wii fit doesn't work
Make sure the program that your are running (ie: Wii Fit, etc) is completely loaded. Your balance board will NOT power up if the software is not running on your Wii.
SOURCE: wii board will not switch on at all no light. Have
Seems the rechargable battery pack was the problem. Switched to normal AA batteries and it worked straight off.
