SOURCE: what do the distance numbers represent on the
If no distance goal was set, this display will show the distance that you have pedaled, in total revolutions. If a distance goal was set, the display will show the distance still to be pedaled during your workout.
SOURCE: nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
SOURCE: nordic track console seems frozen
Since I don't know the model # I will take a wild guess and say they maybe batteries in the upper console that need to be replace or if it has a power supply in maybe the upper console that has failed. Get back to me if I'm off the mark thanks!!
SOURCE: BUYER BEWARE!! I purchased
Watch this video: o 1 Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord. o 2 Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place. o 3 Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled. o 1 Unplug the treadmill and remove the safety key. o 2 Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S. o 3 Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models. o 4 Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw. o 5 Reverse the directions to put the hood back on and the treadmill upright in the original position.
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
2. Reed Switch
Check too:Optical Sensor. If have it
Remove the screws or bolts securing the ends of the pedals
to the crank axles. Slide the ends of the pedals off the axles. Remove any
screws or bolts securing the left and right disc shields to the base unit. Pull
or pry the disc shields off the base unit and set them aside.
Step 2
Remove any screws or bolts securing the left and right side
shields to the base unit. Detach the side shields and set them aside. Examine
the interior of the base unit and locate the drive belt.
Step 3
Pull the drive belt free of the crank pulley, flywheel and
any other pulleys. Discard the old drive belt and install a new belt in its
place. Turn the crank axles by hand to confirm that the belt will turn smoothly
when the device is in use.
sincerely. Merry Christmas.ernesto cuadra
