Error message in upper left of screen...Red Hat Linux release 9 (Shrike) Kernel 2.4.24 on an 1686 cas01 login:vu2010: init_module() fails. There's more, but you get the gist.
SOURCE: pioneer plasma no picture with blinking red light
this requires a replacement of the power supply board. This is per Pioneer tech support whom resolved my issue when I called. Hope this helps!
SOURCE: Pioneer Elite Plasma TV
This a factory issue and usually requires service. Most cases it is a bad power supply caused by a surge or powering off and on too fast ... sorry I wish I had better news
SOURCE: Help with Pioneer Elite Pro-1130HD 50 inch
just wait it, because it is processing the display data
SOURCE: no picture on Pioneer plasma
first of all check out the fuse that mostly get blowned out in this problems.if the fuse is perfect then it could be the faulty capacitor issue check out on the main board with the help of the multimeter and replace the faulty ones and it should work properly.
SOURCE: Pioneer Elite shows pixels at the top of the screen
There may be a failure starting in the matrix drive board, or in the display itself. The area of failure can be verified with proper troubleshooting by swapping modules. These sets are mainly serviced by swapping modules, and then calibrating as required.
Considering the age of the set parts and modules may be difficult to find. Also, these sets are fairly expensive to service. Because of the age of the set reliability will be low even after service.
I would be seriously considering that it is time to start shopping for a new set when the fault becomes intolerable.
Jerry G.
