20 Most Recent Pioneer Elite PRO-1140HD 50 in. Plasma HDTV Questions & Answers
3answers
Pioneer Elite Plasma TV
This a factory issue and usually requires service. Most cases it is a bad power supply caused by a surge or powering off and on too fast ... sorry I wish I had better news
1/22/2023 3:23:58 AM • Pioneer Elite... • Answered on Jan 22, 2023
2answers
My HDMI Terminals for Pro-Ro6u Media Receiver is
This could be an HDCP "hand shake" problem. Try turning both the TV and the connecting device off, connect the two using HDMI, turn both of them back on, select the proper input and see if you get a picture. If nothing happens try the other HDMI inputs by following the steps listed above. I hope this helps.
See the following Thread for more information about problems with the Pro-Ro6u.
http://www.tv-forums.com/forum/TV_Equipment_C4/TV_Repair_Forum_F3/Pioneer_Pro_RO6U_Media_Receiver_P46635/
3/4/2018 1:52:36 AM • Pioneer Elite... • Answered on Mar 04, 2018
I have a 50 inch
My understanding is if any air gets in this area where the glasses are it will not work. You better ask a tv repair man to see if it is worth putting the money in to repair. There should be no charge unless you have him do something to it.
10/1/2017 1:14:37 AM • Pioneer Elite... • Answered on Oct 01, 2017
I can't get rid of closed captioning!
Closed captioning can come trough 4 sources 3 of them access a digital file and display it to the screen. ALL must be set to off on each device: Embeded in actual program video source--unlikely your problem. TV decoder cotrolled by TV menu under "language" Cable box--ditto for menu selection DVD player or VHS tuner--Ditto for menu
9/17/2017 4:04:44 PM • Pioneer Elite... • Answered on Sep 17, 2017
0answers
The screen is black. when I cycle through the different inputs, the input display appears for 3 seconds and then disappears. I get a display of "Plasma Display--No Input Signal".
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
1/5/2017 10:40:37 PM • Pioneer Elite... • Answered on Jan 05, 2017
Pioneer Plasma 50 inch...sometimes the red/green fade. Blue and Yellow are fine. No consitency. TV could be on 1 hr or 6 hrs before it happens?
Its the electrolytic capacitors located in the power supply board. There are 2 of them.
3/9/2015 2:03:12 PM • Pioneer Elite... • Answered on Mar 09, 2015
My picture only shows black and white on my pioneer elite once i unpluhgged it fron the cable box. the box isn't broken and the color on the tv works on the menu if i disconnect the cable
Check the color level for that input. While monitoring the cable box go to the video part of the setup menu. Make sure the chroma or color is up to its normal setting. Some TV sets have independent video settings for each input. This way each input can be separately set up. There is a possibility something went defective thus causing the chroma processing to not work, but this rare. The menus showing in color are from a different built in circuit than the one that decoded and processes the program video.
10/21/2014 3:27:00 AM • Pioneer Elite... • Answered on Oct 21, 2014
Pioneer Elite plasma TV--top half of screen is green
What connection interface are you using. Can you try connecting another form of media and see the performance e.g connect to a computer or another TV box using another cable. If this persist, please visit a TV repair shop or call your manufacturer.
7/14/2014 6:17:24 AM • Pioneer Elite... • Answered on Jul 14, 2014
No image from computer to tv with vga connection
Ensure your TV is turned to computer/VGA input. On your computer use the Windows key + P continuous until it appears on the TV.
3/9/2014 4:49:48 PM • Pioneer Elite... • Answered on Mar 09, 2014
Hdmi ports do not work anymore on my Pioneer Elite Pro 111fd
You can only contact Pioneer service for that problem.
2/26/2014 6:44:35 PM • Pioneer Elite... • Answered on Feb 26, 2014
Weather is it safe to leave TV in standby mode for weeks together?
I suggest that your TV is connected to a surge protector (In case you lose power).. The Standby Mode is safe at that point.
1/12/2014 7:56:15 PM • Pioneer Elite... • Answered on Jan 12, 2014
Pioneer elite turns on then shuts off right away
Shutdown can be caused by many different things in the set. Do you get an blink codes from the power LED on the front of the TV? You can order boards and get help from the technicians from part suppliers I often use.www.tristatemodule.comwww.rivervalleyelectronics.net
11/4/2013 6:41:26 PM • Pioneer Elite... • Answered on Nov 04, 2013
Pioneer Elite PRO-1140HD 50 in. Plasma HDTV Logo
121 questions posted
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
green dots in middle viewing area
  • Televison & Video
