Earlier it used to bring "no disk" message. Now it does not not even open the disc drive but as soon as I try to open the drive, it brings up all the messages like " Open" "close" "Load" and then "no disc" in series.
I think it is not recognising any.
Any help can be appreciated well.
If it is powering up it is NOT the power supply that is at fault. If the door won't open it is likely the belt that moves the tray.
Unplug the unit and remove the screws holding the case shut.
On the left side you will see a metal plate that is the top hold down for the DVDs.
Remove the four screws and pull up on the plate. There will be some resistance as the top spinner is held in place to the spindle by a magnet.
Plug in the unit but DO NOT touch anything on the right side where the power comes in!
Power on the unit and hit the eject button. If the tray slides out now you are partly in luck.
With the tray ejected unplug the power.
Partially push in the tray and look along the front. You will see a small pulley (motor) and a large pulley. There will be a "rubber band" looking drive belt there. Likely that drive belt is dry rotted.
Getting one is the trick. I'd suggest rescuing one from an old CD/DVD drive from a computer.
If it is powering up it is NOT the power supply that is at fault. If the tray won't open it is likely the belt that moves the tray.
On the left side you will see the drive. A metal plate that is the top holds down for the DVDs.
Getting one is the trick. I'd suggest rescuing one from an old CD/DVD drive from a computer. Or possibly an old DVD player.
If you are lucky enough to have an electronics supply shop near you they will have them.
SOURCE: Cyberhome 1600 DVR Format problem
Heat related. Google "Cyberhome DVR-1600" "power supply" (with the quotes included) for answers...or look elsewhere in this forum.
SOURCE: need 3 digit remote code
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600
into a Region Free DVD Player
There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding
CH-DVR 1600 MU
CH-DVR 1600 ZU
SOURCE: cyberhome 1200 dvr
It would appear that this posting represents two (2) separate problems; 1) dead set; and 2) No Disc.
Dead set indicated by "will not come on, no time dislay, disc door will not open" is power related. It could be a fuse, power supply, switching regulator. Repairs would require familiairty with electronic components and circuitry, use of a DVM and a soldering iron. Additionally, acces to a service manual or at the very least a schematic diagram would help in pinpointing defective components.
No Disc - would appear to be a "laser eyer". Am afraid that this is indicative of a weakening optics or the laser. You can of course still give it a cleaning using CD ROM cleaner normally used for computers. Additionally you can try using a can of compress air to force out any dust inside the unit. Other than that all other actions would require opening the unit for a look and see, manual cleaning or worst case scenario, parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
