SOURCE: hp zd8000 power jack replacement
Find the compatible Power Jack for your ZD8000 Notebook available for order from the link below :
http://www.laptopjacks.com/view_part/HP-Laptop-DC-Power-Jack-HP252400.html
Make sure that you get the Power Jack replaced by a well experienced technician.
Hope this helps...
SOURCE: HP Pavilion zd8000 don't startup
remove battery plug in power cable boot up.. nothing may seem to happen but wait a minute or so then press and hold power button down until power light goes out then release button .
try to reboot now.
SOURCE: HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
SOURCE: replacing power jack on HP-zd8000
Ofcourse you to disassemble it and have only the main board and then underneath it is that connection of that jack, so things you need are,
1- Soldering iron and soldering wire
2- Screw drivers
3- Multimeter
4- the spare jack
5- Love / Care for you laptop, so that you dont mess it up.
Cheers
