SOURCE: I need to replace valve
Disconnect power to the dryer then pull the lint filter out and remove the screws near the opening.
Insert
a putty knife blade or similar tool between the top panel and the front panel
to release the clips securing the top panel to the top of the front panel on both sides as
shown then rotate the top panel up to the rear of the dryer.
Disconnect the door switch wire harness then remove
the front panel screws and lift the panel up and off the cabinet.
You
now have access and view of the burner assembly where the gas valve coils are located.
Disconnect the
wires from the coils and remove the screws from the bracket then lift
the coils out. Slide the new coils in then secure it with the bracket
and reconnect the wire harnesses.
Reinstall the front panel from the bottom then up and secure it to the cabinet. Rotate the top panel down back into position then push it against the top of the front panel until the securing clips engage and snap into place
SOURCE: Gas dryer not heating up
Flash, did you check the thermal fuse in the back? On a gas dryer the drum will still turn if it's blown. check out the picture and post back.
SOURCE: Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
SOURCE: Whirlpool dryer (no heat)
does the ignitor light up if it does check continuity on the thermo fuse (the little white one) if ok replace coils
SOURCE: Glow coil lights...but gas valve seems to be stuck.....tests from here?
If you are sure that your model is a Whirlpool LGR5636L gas dryer I can help you. But before we begin look inside the door on side of the door opening and send me (those numbers). Thanks, Sea Breeze [email protected]
