The most common cause for your problem is the gas valve coils. There are 2 and should be replaced in pairs. Over time, they will fire when you first start the dryer but fail to fire again once in mid cycle. A link for a typical set of coils is listed below:
Whirlpool Gas Valve Coil Set of 2
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
