Air circulation blower and induced blower will run continuously even after thermostat is turned off. Observation window indicates a continuous light flashing and according to manual is considered "Flame Sensed with no call for heat". Probable cause is listed as either a short to ground in flame sense circuit or miswiring. System was working fine until yesterday. Circuit board was replaced November 2010. Since heating system was working all winter and AC up until a few days ago I do not think it is miswiring so what exactly is a short to ground in flame sense circuit and can I fix this myself? Would it help if I cleaned the flame sensor? Is there any other cause for this? Any assistance is appreciated and thanks in advance for your help.
SOURCE: Amana Gas furnace, Air Command
Buy a new ignitor here; The Ignitor Store. Or talk an Amana dealer/Contractor to sell you one. They can range from 15 to 35 bucks! Depending on their mark-up. Give them your model number, and or ignitor part number. Their simple to change out, good luck, please contact if you have any questions.
SOURCE: Amana Heat Pump Tripping Breaker
My guess I would say, you either have a wire that is short to ground or if the contacter pulls in, then I would say the compresser is short to ground.There also could be some capacitors that could be short.
SOURCE: Blower motor runs but dies out..
When it does this carefully feel the end of the blower motor. If it is too hot to touch,Replace the blower motor.
Your 5 minute off sequence allows the motor to cool enough for a restart.
SOURCE: heat pump works in emergency heat, but not in auxiliary heat
I set the thermostat for 70 degrees. It comes on always in auxillary heat and does not shut off when it reaches 70 degrees. It is a heat pump, I am assuming, it might be the thermostat? But when the air conditioner is on, it turns off when it reaches it's temperature.
