SOURCE: How do I get my calculator to round to the fourth
Hello
[Shift][Setup][6:Fix]4 displays result with 4 decimal places. But if number is too small you will lose significant digits and may have a null value.
In that case you use [Shift][Setup][7:Sci]4 displays results in scientific notation digit.4digitsx10^(exponent)
Hope it helps
SOURCE: oops
You need to change the display format.
Press the [MODE] key a certain number of times until the screen
displays Fix, Sci, Norm on one line, and 1 2 3 on the next line, with 1
under Fix, 2 under Sci and 3 under Norm.
Press 1 (Fix) followed by a number (1,2,3, etc.) This second number
will set the number of decimal digits. In other words, if you press 1
(Fix) 3 all your results will have 3 decimal digits. If you choose 0,
your results will not show decimals.
Hope it helps.
Thank you for rating the solution.
SOURCE: I have Casio fx-350 MS.
Cheer up, the calculator can display UP to 10 digits, no more. Internal memory keeps 12 digits. So clearly, this calculator is not fit to handle the precision you apparently are seeking. It may be time to look for a more capable calculator.
SOURCE: how do I round 991.5656641
Press SHIFT MODE 6 3 to set the display mode to Fix3. This will show all results with three digits to the right of the decimal point.
