Question about Casio Office Equipment & Supplies
We hit a button on Casio HR-170RC and now it keeps rounding up. How do we stop this?
Posted by Michael A Morgan on
Andrew Taylor
    Top Expert:
  • Casio Master
  • 34,001 Answers
It is the slide switch for decimal places. You needs to be set to 2 places.
Slide Switch ' Printing Calculators ' Calculators ' CASIO
support.casio.com > Support > FAQs > Calculators > Printing Calculators
Q1: What is the [F CUT 5/4] switch or [DEC] F, 0, 2 button for? (HR-8 series); A1: The HR-8 series have a [DEC] key with F, 0, 2, and 5/4 over it, while many other calculators models have a switch labeled [F CUT 5/4]. The button or switch can control rounding off to a certain number of decimal places. F is floating point (no F ... Missing: 170rc
HR-170RC ' Calculators ' Manuals ' CASIO
support.casio.com > Support > Manuals > Calculators ·This page might be unreadable or wrongly displayed depending on your browser, OS version, and settings. In this case, please try with different browser (Chrome, Firefox, etc.) ·We recommend you to download the large PDF files from this site and view them off-line. [ To download a file ] 1.Align your mouse pointer with the ... Missing: rounding
[PDF]HR-170RC HR-200RC - Support - Casio
support.casio.com/en/manual/004/HR-170RC_200RC_WA_EN.pdf - Translate this page
Mar 15, 2017 - Back-up Battery. Your calculator comes with a single built-in CR2032 lithium battery that provides power to retain values stored in memory when you leave the calculator without power (AC ... Weight: HR-170RC: 570 g (20.1 oz) including batteries ..... performed with values as input, and the result is rounded.
Slide Switch ' General Calculator ' Calculators ' CASIO
support.casio.com > Support > FAQs > Calculators > General Calculator Q1: What is the use of the Slide Switch? A1: F: Floating Decimal CUT: Values are cut off to the number of decimal places specified by the current Decimal Place Selector setting. UP: Values are rounded up to the number of decimal places specified by the current Decimal Place Selector setting 5/4: Values are rounded off (0,1 ...Missing: 170rc
Posted on Mar 01, 2018
When I hit the CA button on my Casio HR-100TM, I get two red dots and a black +%%. I've tried resetting the machine and I've hit CA 20 times in a row but Ican't get it to stop.
I rekon ya over load it now by bashing the ca button. try removing the battery, leave it out fer 5 minutes the put it back in then hold the power button down for 5 seconds for a hard reset and it it should be good to go...
Jul 10, 2018 | Casio Office Equipment & Supplies
Set time format from 12 hr to 24 hr for casio LA670W
Was this problem answered? If yes, can somebody tell me how. My Casio LA670W is in 24hr format and I want it back on 12hr format. My watch have 3 buttons only. Mode, Start-Stop and Timer
Nov 22, 2013 | Casio LA670W Digital Ladies Watch LA-670WA...
How do I turn round up off? I don't have a
http://www.usersmanualguide.com/casio/calculators/hr-8te
Go to that website and click download pdf user manual. It is in english and spanish.
Feb 28, 2011 | Casio HR-8TEPlus Calculator
I have a Casio HR-100TM. I have an
Here is a link to the manual. Be sure to check the box that says your not a robot an then download.
https://www.calculatorusermanuals.com/Casio/HR100TM/Download/491396
Jul 23, 2017 | Casio HR-100TEPlus Calculator
How do I change ink cartridge on HR-100TM Casio. Cannot take old cartridge out
the G24 ribbon is having 2 round shape casing. u need to take it out from the knob. but be careful when u install a new ribbon, make sure u slot in the ribbon in correct way
Sep 07, 2009 | Casio HR-100TMPlus Calculator
How to set time Casio W-89H two button watch
Actually, the watch has 3 buttons -- "Light" being the 3rd one. Press Mode until a number in the time mode begins flashing. Then press the Light button to get it to the hour indicator. Use the 12-24 Hr button to set it to the current hour. Then press the Light button again to get it to the minutes section. Again, use the 12-24 Hr. Button to set it to the next minute coming up in the current time. Then push the Light button again. This will bring up the seconds indicator. At the precise time the minute you set before begins, hit the 12-24 Hr. button, and the indicator goes back to zero and begins ticing away. Then hit the Mode button again until the watch is in the current time mode. Hope this helps. I use Internet time to set a precise time.
Jul 17, 2009 | Casio Watches
How do I change the ribbon on my casio hr-8tm calculator?
Place the roll on the wire thing at the back (I don't think it matters which way round); push the paper through the slot at the bottom of the back and then (having taken the clear plastic cover off) push it along the bottom inside at the back as far as you can then start to press the feed button; keep feeding it with your finger and pushing the feed button asnd it should pick up eventually.
Dec 09, 2008 | Casio HR8TM Calculator
Set Tax rate on a Casio HR-100TM
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
Jan 05, 2008 | Casio HR-100TEPlus Calculator
1,231 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
