The TV never comes on the 1st attempt, sometimes 2nd but otherwise shuts off. It Usually must be unplugged 1 to 3 times and makes noises powering up and down before a picture will flash on. Once on the picture is fine though. Sometimes control buttons stop working and I must unplug to turn off and start again. What needs to be replaced to fix this power up problem?
Im going to guess that you have crackling and hissing noises, as well as the infamous "click" then nothing when you try to start the tv. This is caused by circuit failure on the main board, which powers up the main inverter to charge the screen. ( a high voltage thing that makes the picture come on) when the board cannot provide a high enough starting voltage, the symptoms you described start happening. It is not an easy fix, and will probably set you back a couple hundred dollars or so to fix. I hope the best for you
SOURCE: TV makes chirping sound and power button blinks, T.V. does not turn on
It is the lamp, you have to change the lamp, it's in the left side of the tv, have a litter compartiment, opened and take out two screw and take out the change and change it. you have to buy a new one. go to google.com and put the model of the tv and find the price of the lamp.
SOURCE: I have a Samsung HLT5076SX/XAA. The TV will
make sure lamp door is fastened closed, if this helps please give me high rating
SOURCE: I have a Samsung HLR5067WAX/XAA 56 inch, rear
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Here's the instructions to replace it http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php and your part # is BP96-01103A Have a bless one!
Testimonial: "Thank you! "
SOURCE: power up, attempts to turn on, then shuts off,
Replace the three deflection capacitors CP150, CP120 and CP114. You can get the repair kit by that same name from www.tvrepairworld.com which also contains the CD with instructions.
