20 Most Recent Samsung HL-T5076S 50 in. TV Questions & Answers
2answers
Dark picture with white dots
The white dots are caused by a defective DMD chip. Samsung is covering the cost to repair this problem. Call 1-800-samsung and they should set up the repair with the closest service center. A dark picture could indicate that the Lamp is about to go out, mention this problem when you call Samsung.
12/26/2018 8:15:55 AM • Samsung... • Answered on Dec 26, 2018
0answers
The problem with my samsung model hl-t5076s there is three flashing lights one red an two green. The red light flashing is called stand by temp an the two other green light one is time an one is lamp
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
12/20/2016 1:55:17 AM • Samsung... • Answered on Dec 20, 2016
2answers
Samsung HLT5076SX XAA turned itself off. Two
If you do not hear the color wheel start to spin inside of light engine this may have failed also check to make sure fans are working and safety switch is making contact
2/2/2015 2:15:37 AM • Samsung... • Answered on Feb 02, 2015
WHY WONT SAMSUNG T5076S WONT STAY ON?
Check the input sinal cables
9/24/2014 5:05:12 AM • Samsung... • Answered on Sep 24, 2014
How do i replace the ballast in a hL-T5075S
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Replacemsnt procedure to both lamp and ballast to projection TVs are given with illustrations.
4/20/2014 1:32:15 PM • Samsung... • Answered on Apr 20, 2014
Remote IR board
This board can be located at the front panel of the TV. You have to open the TV, to take it out. The infrared sensor can be located just behind the infrared window, whci can be located at the front panel of the TV. The sensor will look somewhat like this. e23a7382-203e-4e46-a063-a2a3486f559a.jpg b2d2b1aa-8774-4903-a7eb-a71b2eef5a8b.jpg 61e4ecaf-7ef3-4e0f-b761-00d01a018133.jpg If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/
1/29/2014 4:14:37 AM • Samsung... • Answered on Jan 29, 2014
0answers
0answers
HL-T5076s changes inputs by itself
The side buttons panel might not get proper voltage. Check it. Replace the side control panel card.
12/4/2012 8:58:29 AM • Samsung... • Answered on Dec 04, 2012
My sa,sung tv hlt5075s is
They do have an overheating problem. It is serious and my husband solved the problem. I wish I could get this out to everyone on the internet. Behind the TV, on the left, is a cover over the lamp and color wheel. Remove it. Buy a SMAL fan at Walmart for about $10 and set it there. Make sure it is running every time you turn your TV on. You will never have overheating problems again. Our TV Samsung would run for about an hour, then the color would washout. NEVER AGAIN. It is perfect.
7/28/2012 3:24:10 PM • Samsung... • Answered on Jul 28, 2012
Samsung HL-T5076S 50 in. TV Logo
68 questions posted
Ekse
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
dark picture white dots
  • Televison & Video
