Televison & Video Logo
Posted on Jun 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Av board jo47
Hey there im looking for spare parts for lcd tv 47inch. model no JO47 part no: CV 109H
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Jun 07, 2012
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008781
Points
237762
Check this link for details. Pictures are there.
2 Related Answers
Anonymous
  • 848 Answers
  • Posted on Jul 23, 2008
SOURCE: av module board
this link might help you
http://www.shopjimmy.com/searchparts.cfm?make=Gateway&t=model&m=GTW-P42M203
Anonymous
  • Posted on Dec 02, 2010
SOURCE: baird 47 inch hd tv
baird 47 code for sky remote
Can i connect an external amp and speakers to my jo47 lcd baird tv
I don't know your TV but I would say you can. If tv has audio out then there is not a problem. If not, check if there is headphone jack. If yes then you will need 3.5mm headphone to rca (chinch) adapter.
1helpful
2answers
My Vizio 47inch TV made a loud pop and shut off. Pulled back off and inspected for anything bad. Located a tiny resistor looked like it was burnt or something can it be fixed?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
My Baird jo47 won't turn on and the standby red is flashing with sound what is the problem
My baird JO47 tv is stuck on standby - Digital TV - Streaming ...
www.tomsguide.com/forum/55998-4-baird-jo47-stuck-standby
Dec 17, 2012 - 4 posts - ‎2 authors
My Baird JO47 tv is stuck on standby and won't come off. ... I have a panasonic 50" TV it will not turn on no green light or standby red light ... Forum; my tv standby light keeps flashing blue on and off and won't switch on Forum ...
Baird JO47 Stuck on Standby ' Electronics Forum (Circuits ...
LCD TV diplays blue screen on all inputs
Nothing on all inputs would suggest the Main AV board not processing signals, if all other functions such as volume, menu access, on and off operate normally the power supply board is probably functioning OK. Have a look at shop jimmy for an idea on price and availability for Mitsubishi LT-46144 Boards and spare parts:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Fogot my tv code to reset tv Baird jo47 how do i reset code
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 24, 2012 • Cell Phones
3helpful
Sky remote code for tv model JO47 Baird
These are your codes,0117,137,221,371,218,220,236,100...Here is a link for directions, www.digitalsat.co.uk/skyremotecodes. hope this helps..
4helpful
3answers
Power Light
The most likely failure is the main power supply. You may be able to identify it with the following instructions:
Unplug your set overnight to allow potentially hazardous voltages to discharge, remove the back panel of the set so you can see the guts.
Look for a smaller board with larger parts on it; some cylindrical (capacitors), others block-like and relatively large (chokes and transformers).
You should also see a relationship between the board and the incoming AC.
Check the board for a label or if not present, a stamped-on number.
Call the manufacturer's service center with your TV model number and the number found on that board and inquire about repair/replacement costs; if both are offered, they won't be that much different.
If you must buy a new board, don't dispose of the failed one as there are smaller companies that can repair it for less than the mfr. and then keep it as a spare as this problem will likely arise again.
Unfortunately, the Magnavox name is owned by the Japanese Funai company which is known for poorly designed and not very reliable products.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
