I would like to replace a dead battery in my nuvi 1390 I need to know what size wrench to buy to open the case.
SOURCE: replace battery garmin 255
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
SOURCE: Open the case of a Garmin nuvi 255w
i am wondering why you want to open it.
There are some small parts that will fall out unless you are very careful and even more difficult to put back when you try and close it up
. Other than to change the battery there are no fuses or user repairable parts inside.
SOURCE: Replace Garmin nuvi 255 LCD screen
If the touch screen is working well,then you only need to buy the LCD sreen,but usually suppliers will send the LCD with touch screen as they are one whole part.you can try to contact :
[email protected] for further information about it.
SOURCE: how do I open Garmin nuvi 650 to replace battery?
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the
StreetPilot C300 and C500 series do not have user replaceable batteries. These
units must be sent in to a Garmin approved repair facilities if a battery
issue arises. Garmin and Raytech are the
only Garmin approved repair facilities. Raytech is a repair
facility for Canadian customers. To
repair your device please contact the specific repair facility for your region.
If your device is not still under the 1 year warranty, there will be a cost
associated with the repair of your device.
Are you sure you have a dad battery?
Normal
0
false
false
false
font-size:10.0pt;
If your GPS unit powers down before it can fully
boot up, the battery will need to be charged. Please charge the unit
with the vehicle power cable or on a computer for at least three hours.
After charging the unit, it should power on and function normally. If the
unit will not charge in the vehicle, check the fuse in the power cable for
the unit and the power outlet in the vehicle.
MAKE SURE to use a Garmin charger!!!!!!
SOURCE: Replacing battery in Garmin Nuvi 650
I discovered a video on how to replace the Nuvi 650 battery. Hope this helps, Rob
