Zynga FarmVille by Zynga Logo
rhonda moore Posted on May 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Farmville taking away prises, and not letting things go thought
Yesterday on Winter wonder land, I finally finished getting enough pickackes to get a prise. It would not let it go though, even after I had gotten 45 pickackes. they even took 25 more of the extra pickackes . This is not the first time, they have not let me have things that my friends sent me. I still do not get all my prises.
Anonymous
Level 3:
  • Master 821 Answers
  • Posted on May 31, 2012
Anonymous
Master
Level 3:
Answers
821
Questions
0
Helped
159146
Points
2407
That is a farmville issue we don't adjudicate the farmville or facebook platform here at fixya
2answers
I recived 20 farmville bucks when i purchased land and i did not use any bucks and it says i have only 14 this is the 3rd time this has happened please explain
You must contact Zynga.com. or at the bottom of your farm screen, click support. In that link, to the right...click the red words..."get help" it will take you to a screen where you can email or maybe chat with someone who can look into this for you.
2answers
2000 grand marquis driver's side windshield wiper lifts off windshield
Hello Steve,
From your post, "Finally had enough and stuffed a small block of wood between the driver's side bottom of the molded plastic linkage frame enough to lift the whole thing enough to put a moderate amount of pressure behind the wiper blade..", it sounds like this box is warped or somehow out of alignment. Is it possible for you to buy this box from a wrecking yard? Has you car ever been in a collision? If so the frame may have so un-repaired buckling resulting in the misalignment.
5helpful
7answers
When I am on farmville , my trees and other bits are not loading. just circles.
You need to remember that Farmville is still in beta. If you are able to load Farmville then Flash is working properly on your computer. The problem isn't on your end, it's on Zynga's side. Give this a try... Open up Farmville in a completely different web browser, like Firefox or Google Chrome. If you're still having the same problem, then the issue is on Zynga's side and not yours.
If it works in one browser but not the other, come back to this page and post a response. I will be happy to assist you further. :)
1helpful
2answers
Farmville said to refresh as game is slow or freezes the comp Ihave uploaded adobe again but does't work I am a fairly new user but age well let say mature
It sounds like you may not have enough memory in you computer to run farmville. I have 2GB in my computer and it runs a little slow when playing farmville.
1helpful
I cannot access my farmville app went on it about
* If it's a flash player problem, try this :
1. Install the latest and updated version of Adobe Flash Player.
2. You can get it from :
http://get.adobe.com/flashplayer/ (Slow URL)
http://filehippo.com/download_flashplayer_ie/ (Fast URL)
3. After install, restart your system.
* If still the FarmVille page is not accessible, try this :
1. Open your web browser.
2. Goto Tools >> Internet Options.
3. Delete all Cookies, Temporary Files and History.
4. Apply the settings and restart the browser.
* If even now the page is not accessible, the problem is the busy server! Please try to Refresh/Reload the web page!
tell me if it not works...tc! :)
*** The 'FarmVille' game application is under maintenance since yesterday because of the connection problems reported
by the users. So, please keep patience till tommorow when all the errors in the application will be repaired! Enjoy Farming !!! ;)
Cbr 600 grtting ready for winter
top off the fuel tank to reduce the amount of air in there, less open space means less room for condensation to form and cause rust in the tank. next drain the float bowls if you dont really like pulling the carbs in the spring. also put the battery on a trickle charger to keep it from going bad.
Hitachi 43fwx20b intermittent vertical hold loss...humidity?
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Samsung 52 inch rear projection TV
Probably harm the finish more then the electronics. I would move the set away from the fireplace man. Common sense should tell you that!
Top Zynga Apps Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Zynga App Expert? Answer questions, earn points and help others
