Sounds like the video card inside the computer is bad. If the monitor
was bad it would not be able to display the No Input Signal. To make
sure, try connecting another monitor to the computer. Borrow a monitor
from a neighbor, friend, relative or co-worker and connect it to the
computer. If the Borrowed monitor displays the same No Input Signal
message then your video card is bad. If the Borrowed monitor displays
and works ok, then your original monitor or lcd screen is bad.
If you have a laptop, The video will show on most systems when you
reboot without you having to do anything. Some systems will require you to hit
the FN (Function key) + F1 thru F12. Hold down the FN key then hit the
correct key for displaying on the monitor (F1 thru F12). The correct key
will normally have CRT/LCD on it or it will have the icon of a display.
not video card not monitor.monitor works on other puter,put in graphics card i knew worked,used integrated graphics on mobo,get same response this is my 1st solo build and i'm getting po'd lol
