This problem happens when the cartridges are not properly aligned. With the printer turned on, open the cartridge access door. The carriage will move and then stop. Now uninstall the cartridges from the holder. Clean the electrical contacts on the holder and then reinstall the cartridges. Make sure the cartridges are perfectly placed into the holder. Close the cartridge access door. Turn off the printer and now turn it on. Check if the printer says Aligning cartridges. If this is not working, then hard reset your printer. With your printer turned on, unplug the power cord from the printer and the wall outlet. Wait for a few minutes and reconnect the power cord. The printer should turn on automatically. If it does not, then press and hold the power button to turn it on. Resetting the printer will fix most issues dealt with the printer.
123 HP COM Setup Printer Quick Setup and Install Support
SOURCE: Problem faxing-error message
Error 388:
Definition
There is too much noise on the line
for a valid connection between two fax machines to complete. The noise
problem might go away over time.
Solution
Retry
the fax reception at a different time when telephone line conditions
have improved. Call the telephone provider if line conditions fail to
improve.
Error 403:
Definition
During a V.34 transmission, the
local machine is unable to connect (handshake) with the remote machine
and is consequently unable to send a T30 frame. This occurs when the
line is disconnected or if line conditions degrade during the session.
Solutions
