I had just fixed my controller with that problem. Theres a tiny hole on the back of the controller. That is the reset button. Get something really small and thin so it can hit the button. Once done turn on your PS3 and plug up the controller with the usb connector. Once done press the PS button then it will start blinking and then assign a controller number
SOURCE: All lights on Dualshock 3 blink 5 times, then do nothing.
On the back of you dualshock pad next to the L2 button there is a tiny small hole witch looks like it could be a screw hole ! well this is the reset button once you have pushed this you will be able to conect your pad to your usb cable and it work on your console again
SOURCE: PS3 Dualshock Does not Charge.
hi i had this problem my controller would not charge although my head set would useing the same usb cable .i brought a new controller and tried two usb leads it was no different .this is the silly bit go and buy a new genuine ps3 usb cable and and i promise you all your problems will be solved .i have no idea y the cables stop working with only the conroller but they do i hope this helps all you people pulling your hair out trust me this will work
SOURCE: PS3 Controller wont turn on?
mine sometimes does that, just try pushing and holding it until the options come up on the screen, then turn off controller. Then try turning it back on. If that doesn't work, turn the ps3 off when its done charging, then unplug it while its off. This should work.
SOURCE: My Dualshock 3 controller will not work. When I
playstation 3 controller will not work all the lights are on but no go
SOURCE: all light blinking then two lights stay on and no button works,
Ok, you've probably already figured this out, but you are in possession of a worthless POS fake PS3 controller. Congratulations: http://www.youtube.com/watch?v=mji_PLB7Tb0
Don't feel bad - i just bought a used white ps3 controller from gamestop and it was FAKE. they better take this back....
