Since you tried your battery on another pc, then try a different charge power supply on yours. You may have a bad power supply adapter or your battery terminals on your pc may be dirty and need to be cleaned with rubbing alcohol and a cotton swab.
Simple-- you can also do this during the day on an object at least 100 yards away-- but at night; get the moon centered in the eyepiece and without moving the telescope center the red dot on the moon. This will get you almost aligned-- then put a bright star in the eyepiece and readjust the red dot to center the star.
I have a 1997 Acura 3.5 RL and my remote unlock doors button dont work cause of the battary so I change the battary and it still dont work then I found out that I need a code to reset the remote also when I put the battary in the red light just stay on do anyone know about this
I'm guessing this is a laser printer so start by cleaning the drum.
If you can give us more to go on, such as; make and model of printer? Is this only with one document or every document? are the dots in the same place every time? Have you cleaned the print heads/drum? Have you changed your brand of ink/toner? Does your computer give you an error message when you print?
The more information you provide the less of a stab in the dark our answer will be.
