Display disc error
SOURCE: Hi I need the hadware disc for sony portable minirecorder mz-n505
Go to Sony Support and check downloads area where you can get driver and SonicStage for your MZ-N505 Sony walkman.
SOURCE: Sony MZ-N505 - says mini disc is blank
Hi- it sounds like the record head is bent or needs adjustment. I do repairs on Sony minidiscs, so you may contact me at: [email protected] for help.
Jacques
SOURCE: Recording from computer to a Sony MZ-R55 mini disc
You can use RK-G136 or RK-G129 cable to transfer music in MZ-R55, insert cable in Line-In terminal.
SOURCE: Sony Mz N910 info...
i have a n910,yes it has a mic out on it and u can record from an audio source.i used mine at the weekend to record my dj set,just make sure u get a manual with it as i'm having a few problems with record levels being too high,but it's a great bit of kit.
SOURCE: SONY Walkman Mini Disc MZ-R70 W/Remote RM-MZR55..
are you using the computer with it, or using a line input or microphone input? How is the battery? If the battery gets really low it will do a TOC EDIT to save what you've got, or you lose everything.
