Marker arms
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
SOURCE: our john deere sabre 17.542 hs ride on mower will
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
SOURCE: How do I replace a hydraulic pump on a John deere
The pump is located in front of the engine.A coupler joins it to the front crank shaft pulley.
SOURCE: how to rebuild hydraulic pump on 4440 john deere
This is something that you need to have special tools to rebuild pump, your best bet is buy a rebuilt from a rebuilder manufacture.
