Samsung N150 Plus 101inch netbook Logo
Posted on May 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen display is upside down
The display is upside down and i have to direct the curser in the oppositte way to where i want it to go
Martin Clarke
Level 2:
  • Expert 186 Answers
  • Posted on May 10, 2012
Martin Clarke
Expert
Level 2:
Answers
186
Questions
0
Helped
67013
Points
498
Change the rotation in desktop display settings.
right click select properties>settings>advanced there should be a tab with rotation settings at the top.
3answers
How do I fix display show upside down. TCL LED TV Model: L24T2100
http://www.tomsguide.com/answers/id-1989729/picture-flipped-upside-fix.html
Screen upside down
Go to the "Start menu", click "control panel", then click "hardware and sound", click "display", then click "change display settings", then click the down arrow next to "Orientation" and change it to be flipped in the direction needed.
2helpful
My screen has turned so that everything is from top to bottom and not side to side
Upside down screen
To change your display orientation within Windows XP is to hold the Ctrl and Alt keys, then press the left, right, up, or down arrow key corresponding to the direction you want the screen aligned with.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Screen display has turned upside down
If you're Windows user you can try this out.
Will flip your screen to four direction
CTRL + ALT + LEFT ARROW
CTRL + ALT + UP ARROW
CTRL + ALT + RIGHT ARROW
CTRL + ALT + DOWN ARROW
2helpful
3answers
How to flip the display
If you are running windows 7 you can simply right click the desktop select screen resolution and then change the setting under the orientation drop down menu.
The page view on my HP computer is rotated sideways...the curser, the infor on the screen etc is a quater upside down...is there a setting to fix this?
Some videocards have keyboard shortcuts that can rotate your view. They normal consist of Alt Ctrl Shift and Left Right Up and down.
So start pushing some buttons.
Like Alt+Ctrl+Left
Shift+Ctrl+right
Shift+Right
and so on.
6helpful
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Monitor
Ctrl,Alt and the arrow up, down key should fix it. Check your pc because some use a different key code. If no right click on desktop, go to properties, display settings and adjust the screen.
38helpful
2answers
Flipped\upside down screen on my compaq
http://forums.techguy.org/tech-tips-tricks/336002-windows-xp-flipping-screen-upside.html
Windows XP: Flipping the screen upside down and back again
Once, at University, someone had flipped the screens of all the public computers (running on Windows XP) of the English Department upside down. The wallpaper, desktop icons, fonts, mouse-cursor and even the start-up screen...everything was displayed or moved upside down. People could not check out their e-mails or surf or do anything.
To reverse the upside down screen mode, press ctrl, alt and the up arrow (arrows console) at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again. If you possess a sense of humour or are antisocial, press ctrl, alt and the down arrow simultaneously, turn off the monitor, turn it on again and everyone (excluding the culprit) will be desperate --> upside down! Works for Windows XP Home and Prof.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
