LG 32LD550 32 in. LCD HDTV Logo
Posted on May 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote control stops working
After about half an hour, either the remote control stops working or the TV stops responding to it,....why? What can I do?
Anonymous
Level 3:
President:
  • Master 2,080 Answers
  • Posted on May 04, 2012
Anonymous
Master
Level 3:
President:
Answers
2080
Questions
Helped
928002
Points
6465
Sounds like it may simply be the batteries dying in your remote. Try putting a fresh set in to see if that helps at all.
Also be sure to check the battery terminal contacts inside the remote control's battery compartment as well to ensure there is no corrosion deposits which may cause intermittent faults. Clean / scrape off any rust or deposits with a flat head screwdriver or something similar until the metal contact is shiny again.
Good luck.
2 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jun 28, 2010
SOURCE: remote control stopped working
The problem can be in the IR receiver, it either not getting the 5vdc, or it failed, or the logic board is bad.
You will need to find out if the signal get to the logic board when the IR receiver gets the signal from the remote control.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=LG+42LC2D+
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Sep 22, 2010
SOURCE: My LG TV does not respond to the remote control.
Try using a small miniphone plug such as headphone and plug it into the remote sensor jack on the back, do that a couple of times to clean the contact switch inside, see if that will work first, if not, then you may have IR receiver board problem. Please post back.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Why has my JMB TV stopped responding to the remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
3answers
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
Hitachi TV
If your remote transmitter is multifunction, such sa TV; DVD; and VCR operative; You may be in the wrong mode. Press the TV function first and then try to change the volume. If you still have problems, the remote may be defective.
7helpful
3answers
My TV won't respond to the remote control
If the remote is working but the TV will not respond, it means that the little IR receiver in the TV has stopped working. This is most likely because the receiver has burned out, but it could also have come loose. This is a very easy thing to correct, but the set should be serviced by a qualified tech.
TV will not respond (on and off) to remote or controls on the TV itself.I need to constantly shut off the TV for a few hours and wait before plugging it back in.It then works for another 1/2 hour or so and...
your tv has some problems, firstly components are heating up on the power supply, later after a power supply is repaired check batteries in the remote. the power supply is a main driver of a tv in terms of switching on & off. thanks
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
