Try installing the latest audio driver.
You can download the audio and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
SOURCE: toshiba m35x s149
Hey i just read your post and i have the same proble with my laptop did you find any solution for the problem
SOURCE: Atheros wireless problem
Ok, if your using Vista, what i want you to do is right click "computer" select "manage"
and then "device manager", then click on the + sign next to "network
adapters" and right click on the wireless network and "un-install" the
device, reboot the PC and wait for windows to detect the wireless
card and install the drivers for it, this will appear in the system
tray (bottom right hand side) when its done try to connect again
keep me informed please
regards and don't forget to rate us please
SOURCE: keyboard replacement for toshiba m35x S149
Above the keyboard - between the keyboard and the screen there is a plastic piece that if you take a small screw driver you can pry off just above the keyboard or at the hinges. Be very careful not to scratch. If you are worried about scratching ifixit.com sells a tool called a spudgner that is soft plastic. This is what the pro's use. Once you have that plastic off you can simply unscrew the keyboard.
Be carefull when lifting the keyboard off. It is attached with a thin ribbon. the ribbon is held in with a clip. gently pull on the clip until it release the ribbon. Once you have the old keyboard off simply push the ribbon in the clip and force the clips back down. Then just reverse the previous steps.
Good luck
SOURCE: I suspect that my video card is going bad. It is
To check if the video card is faulty, connect an external monitor to the video port, power up the monitor first and then the laptop.
The video data should automatically divert to the external monitor, if you see a normal Windows image on the external monitor, then the video card is OK and the fault is the LCD screen and or backlight.
If you don't get any images then video card is probably faulty and because it is built-in on the motherboard it cannot be replaced or repaired.
You could replace the motherboard but this might not be cost effective.
SOURCE: Where is the cmos battery located?
It is located on the mother board, under the keyboard.... It is the size of a quarter.... and may be soldered in on your Satellite M35x series machine.
