I don't know what those product in websit ,and what they use for and how to buy, anybody give some ideas? http://www.xcardiag.com/wholesale/hard-disk-for-super-mb-star-201109-external-hdd-fit-all-computer-format-701.html
Http://www.youtube.com/watch?v=WZKXKcfvKOk&context=C45ff469ADvjVQa1PpcFP-YPDOHB85F3qGu1E4g0TPX4NUdRb25OM=
Hard Disk for Super MB STAR 2011.09 External HDD Format
Hard Disk for Super MB STAR 2011.09 external HDD Format is software for Super MB STAR, software version 2011.09. It works together with Super MB Star. It can used on computer with windows xp computer. Your computer need have serial port.. It is only one hard disk and it is DELL D630 format, so it can used on computer with windows xp computer. Your computer need have serial port.
2. It works together with super mb star and it has usb key in the package.
3. Software version is 2011.09. Update on www.supermbstar.com
Package including:
1pc x Mobile HDD with USB Cable
1pc x USB KEY
1pc x Verification Letter with Password inside
Contact information:
Skype : greebid6
UOBD2.COM
MSN: [email protected]
[email protected]
E-mail: [email protected]
If any problems,pls feel free to contact us.
How to purchase on UOBD2.COM?
hope it helps
SOURCE: usb2.0 hdd external hard disk-unrecognizable device
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
SOURCE: Hi, How to format external hard disk whose file
OK try this
USING DMZ When you enter into your router config window,
you need to find the Tab DMZ, it should be under applications and gaming
if you are using Linksys. Once you find the DMZ tab, click enable and
type in the last digits of your XBOX into the box below. Yes when you do
this you are opening all the ports on your Xbox, which is insecure, but
show me someone that has hacked into an xbox 360?
<MAKE SURE YOU SAVE SETTINGS>
Using Port Fowarding After you have enabled DMZ, find the
Port Fowarding tab, should be under advanced routing. For the name type
in XBL or whatever you want, and for port range put 87 to 89, choose
UDP, then your XBOX last digits, and enable. Then do 3073 to 3075 choose
TCP, then your XBOX last digits, and enable. Then again do 3073 to 3075
choose UDP, then your XBOX last digits, and enable.
after done - then cold reboot both Router and Xbox
XBOX go to the system blade, choose network settings,
then test connection. This may take a bit, but when it gets down to NAT
type it should say OPEN.
Acrobat can't run correctly if the system doesn't meet the following requirements:
