I have a Seagate 9sd2a3-500 320 GB External Portable Drive... Few weeks back it was working fine...but suddenly my laptop did not recognize he device... tried it on some other system...it got recognized and installed all its drivers...!! but the drive didn't show up in my computer the drive just blinks a green light every sec....!! Disk management halts at "loading disk configuration information"...!! Device manager shows the drive installed and running....but can't populate any drive...Its being long since it got crashed and if u guys have any solution to this problem plz do answer..!
Improve the Fixya experience for everyone by voting!
It sounds as though you have one of the following problems:
SOURCE: WD1000VE external hard drive not recognized
If you had check it out on another computer and still nothing just buy new external ( HDD IS FINE ) then put hdd in new external.It's not to expensive
Beni
SOURCE: Beyond micro mobile disk BMMDU2 is not recognized
The drive USB interface may be damaged; an external case is available form various vendors for about $20. The drive should pop out and into the new case. If still not recognized, then the ID track on the drive may be compromized - that can happen if the USB is unplugged while it is still writing to the drive. There is drive recovery software out there, like EASEUS that works quite well (they have a demo that you can try free) to see if that would work.
SOURCE: Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
SOURCE: External 500gb hard drive not readable
Check the partition size in Disk Management (if running Win7 - download a free Partition Manager if not) and see if the system is seeing the partition correctly. Seagate has recovery software available on their website but you may just have to repartition and reformat.
SOURCE: Every time i connect my
Has the disk come with a usb cable that has 2 big plugs?
If yes:
Try plugging both in.
If no:
Take your device to customer care.
