20 Most Recent Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive Questions & Answers
UNABLE TO DETECT EXTERNAL HARD DRIVE
Is the necessary driver installed?
7/18/2017 10:23:42 PM • Seagate... • Answered on Jul 18, 2017
Flashing LED light
Did you drop it? If you did, bust it out of the shell and take the actual hard-drive out. Then get a slaver (aka: a disk cradle/dock). Those run about $20 at most. Otherwise, there might be something wrong with the cord or your USB drive.
4/6/2014 1:54:04 AM • Seagate... • Answered on Apr 06, 2014
Driver won't install
Make sure your computer is up to date with the latest MS service pack. If it is then find the driver you need download it and run it.
1/27/2014 5:24:53 PM • Seagate... • Answered on Jan 27, 2014
My 320gb hard is showing
You bios is limiting the hard drive. If you can update your Bios, the update should correct this. Very common in older IDE based XP installs.
The other option is that you set a partition size on it and just need to make the partition larger.
2/17/2011 10:14:12 AM • Seagate... • Answered on Feb 17, 2011
Flashing leds on both the power adapter and the external drive
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
9/29/2010 9:38:03 AM • Seagate... • Answered on Sep 29, 2010
Can't see Seagate external hard drive on Vista devices with remov
dougv52
If the drive is not showing up in My Computer but is showing in Device Manager then you most likely need to assign a drive let you the drive. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
8/18/2010 9:00:25 AM • Seagate... • Answered on Aug 18, 2010
I have a seagate external harddrive that my father
When you say lock the drive are you asking to lock access to the drive entirely when you disconnect it from your computer no one can access your files if they find the drive and try to put it on their computer and open it,
4/20/2009 10:42:42 PM • Seagate... • Answered on Apr 20, 2009
Seagate hard drive
Is this internal or external drive?
2/12/2009 1:14:38 PM • Seagate... • Answered on Feb 12, 2009
External drive not being accessible from Vista Home Premium x64
format  the external drive,and try again,,,,,,
1/24/2009 4:07:25 PM • Seagate... • Answered on Jan 24, 2009
Only 100gb of my 200gb hardrive are showing
Welcome to the wonderful world of windows disk size limitations.
What you are running into is the Windows 137GB Capacity Barrier AKA the 48-bit Logical Block Addressing Support for ATA (IDE), Serial ATA or ATAPI disc drives.
In English this means windows will only “acknowledge” between 127 and 137 Gig of a disk drive without some updates.
In most cases after he latest Service Packs are installed, any additional gigabytes will show up as unallocated space on the drive and you can create a second partition with the Windows disk management tools. Unfortunately this will mean that you have 2 partitions on the drive (if you placed your os on the drive or partitioned it before the updates were installed.).
If this is a secondary drive (in other words your OS is on a different disk drive), install all of the system updates first, you should then be able to format the entire drive as one partition.
1/8/2009 1:39:56 PM • Seagate... • Answered on Jan 08, 2009
Extenal hard drive
then use a data backup utility and back your data
9/3/2008 6:45:22 AM • Seagate... • Answered on Sep 03, 2008
6answers
External hard drive stopped working
plz try in another usb slot, if the problem persists then try to format the hdd and check.
9/2/2008 12:22:53 PM • Seagate... • Answered on Sep 02, 2008
2answers
Hardrive help!
Unfortunately this is a little like closing the gate after the horse has bolted. as there is a possibility that the files you copy onto the drive may be infected with the virus. however, It is usuall that External drives are not configured for use (as the application for the drive's use is varied) it is up to the user to partition and format the drive. if you are using win XP it sh a case of connecting the drive (the hardware should be detected) install drivers if neccesary. Then the Disk needs to be prepared, Right Click "MY Computer" and select MANAGE. This should take you to a management window. Select "Disk Management" Under "Storage" from the "tree" on the left of the window. You should now see on the top right a list of named partitions, and below you should see the partition maps of the drives connected to the system. your 100 GB disk should be shown here, as an unformatted unpartitioned disk, once this disk is selected you can partition it any way you like however most choose a single partition, once the disk is partitioned you need to format the partition, FAT32 is the most portable. once this is done the disk should now have a Drive letter, This can be changed if required. yould now be able to access the disk :) `
1/22/2008 12:30:41 PM • Seagate... • Answered on Jan 22, 2008
Power supply Adaptor
Just to be sure, is it the power supply that is faulty, or the harddrive 'case'?
If you have a separate power supply, you can find a new one for something like 15-20$
/michael
why pay for software?
12/19/2007 8:58:38 AM • Seagate... • Answered on Dec 19, 2007
2answers
Tool to remove bottom plate
The screwdriver you need is a Torx T10 screwdriver. Just get it from a hardware store, ask for a Torx (size T10) screwdriver. Good Luck!
7/17/2007 8:18:37 PM • Seagate... • Answered on Jul 17, 2007
How to delete backup on my seagate backup plus slim
Detailed steps to manage backup disk space
To delete old backups on Windows 7/8/10 using AOMEI Backupper, you need to set up Backup Scheme during the process of creating a backup. When your backup versions exceed the number of backup images files, AOMEI Backupper will delete older backup automatically. Step 1: Connect your Seagate Backup Plus drive or Central hard drive to the computer and make sure it can be detected by your computer. Step 2: Download AOMEI Backupper Professional, install and launch it. Step 3: Click Backup and File Backup subsequently Step 4: Choose the files and folders you want to backup and pitch on a path for it. Then, Click Schedule option and select Schedule Settingsfrom the following window. Step 5: Click Scheme option, tick Enable Disk Space Management and select whatever Scheme you need from the drop-down menu. Then, back to the main page of File Backup and click Start Backup. After that, your older backup will be deleted automatically when your file backups exceed the versions of backup image files.
2/26/2024 7:21:41 AM • Seagate... • Answered on Feb 26, 2024
Ive got a 8tb seagate its got a blinking blue light and wont connect to my Pc? Any help?
Did you initialize it?
7/3/2023 8:38:03 AM • Seagate... • Answered on Jul 03, 2023
Seagate Portable Hard drive 4TB, part number 2N1AP6-500
Hi, Please put your computer into safe mode before attempting to connect to the hard drive again. Safe mode turns some feature off when activated so whatever program is forcing the shutdown might have be paused when connecting to the external hard drive. Also, try connecting the hard drive to a non-laptop intermediary device and then connecting that device to your computer and attempting to access the hard drive folder within the intermediary drive. Thank you.
11/11/2022 2:11:28 AM • Seagate... • Answered on Nov 11, 2022
2answers
How to recover data from a dead Seagate external hard drive on my Computer?
Should be careful with the data file deposited on the Seagate external hard drive. your Seagate external hard drive might be dead or corrupted. In this situation, you might need to rely on data recovery software to get back data and files on the dead Seagate external hard drive. So you can rely on data recovery software to get back lost data and files when the Seagate external hard drive is dead and inaccessible. Data recovery hong kong technician provide the Ontrack EasyRecovery data recovery services are able to recover data and files from accidentally formatting, corruption, virus attack, dead, system crash under different situations Seagate external hard drive on Windows Computer. This data recovery software allows you to deep scan the dead Seagate external hard drive so as to find out almost all lost files with original quality in a short time. You can also rely on this software to recover files from dead/damaged Seagate external hard drive. The software supports to get more recover: Seagate External hard drive, data file, documents, PDF, Excel, photos, music, and videos any HFS, HFS, FAT, ExFAT, and NTFS format based data and file and more. It will recover data and file from all external storage devices that can be recognized by your Windows PC Computer/Laptop. Hope this helps you get to recover all your lost data and files from your dead Seagate External hard drive.
10/8/2021 1:02:33 PM • Seagate... • Answered on Oct 08, 2021
What enclosure is compatible with a Seagate Barracuda 7200.7 SATA Drive?
TRY LOOKING FOR TIGERDIRECT .COM THEY SELL STUFF FOR COMPUTERS
10/3/2021 8:21:41 PM • Seagate... • Answered on Oct 03, 2021
Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive Logo
21 questions posted
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Seagate Computers & Internet
Most Popular Question
seagate external harddrive father
  • Computers & Internet
