SOURCE: waiting for valid gps signal
Go to TomTom Home on your computer and do a update for your unit. In the update list you should see a GPS quick fix which helps the TomTom's aquire a signal faster. Hope this helps.
SOURCE: i am not getting satalite signal on my tom tom xl
The most common problem to this is because the TomTom doesn't know it's current location. It may be that you last used your device a long distance from where you currently are now. I don't know how long you waited for the gps signal to acquire but it can take up to 10 minutes (even on military aircraft if they don't know current location).
Power it up and press on the signal strength icon. That will bring up your satellite tracking status. If it don't look like it's doing anything, then your gps has probably malfunctioned. If it looks like it's acquiring satellites, then give it a good amount of time (10-15 minutes) to see if it can find your location. I recommend doing it outside of your vehicle with no satellite obstructions to make the process go faster.
Good Luck
SOURCE: tomtom stuck on waiting for valid GPS signal for 3 days
u need to up date gps if that dose'nt work sounds like it needs to be repaired i had same problem and found its better to buy new on then pay 275.00 to repair due the math
SOURCE: "Waiting for a valid GPS Signal...."
the unit will only connect with the satelites out doors my man
SOURCE: tom tom comes on but,no gps signal lost for hours.
hi you need to reset the unit at the back near the connection there is a small button that needs to be held down when holding the power button on for a few seconds. once you have done this turn it on and it will work fine
