SOURCE: digital card
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Testimonial: "omg. i've been going crazy for wk.'s with this issue. never knew there was a lever on the card. i can't thank you enough.the sites a must."
SOURCE: When my camera is switched
Hello there,
You get this error when your card is write-protected. To unlock it, you have to take of the memory card from the camera. Usually its along the battery compartment. But you have to check the other sides just to make sure. One you have the card, look at the sides for a small switch. Push it the other way around to disable write-protect. Put it back to the camera and test.
Hope this helps you and someone out. Good luck!
SOURCE: My card is locked on my k2000 digital camera. How do I unlock it?
There is a little sliding switch marked 'lock' on SD card. Move it up to unlock it.
