20 Most Recent Canon IXUS i7 Digital Camera Questions & Answers
Shutter speed on canon i7
Hi there:I suggest visit this link in order to DOWNLOAD I7 USER GUIDEHope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using FixYa, have a nice day.
8/1/2012 9:13:02 PM • Canon IXUS i7... • Answered on Aug 01, 2012
Camera states on screen that "card locked". How do
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
10/6/2011 4:12:08 PM • Canon IXUS i7... • Answered on Oct 06, 2011
I have a cannon pc1229 I want to download picutres
canon pc1229
power is not working
8/29/2011 4:58:54 PM • Canon IXUS i7... • Answered on Aug 29, 2011
My digital camera ixus 8515
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
8/20/2011 5:26:53 AM • Canon IXUS i7... • Answered on Aug 20, 2011
I just want to ask
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
11/27/2010 10:15:41 PM • Canon IXUS i7... • Answered on Nov 27, 2010
I can take photo.. but
Cost of repair would be probably more than the camera is now worth. But is the screen just showing black? An issue with the tiny SD10/20/30/40... cameras (IXUS versions also) was that sometimes a little corrosion could form on the A/V plug switch that would in effect simulate the plug being inserted, thus turning off the screen. If you have your television video plug available, try inserting and removing the plug in its A/V port a few times. If this is the problem with your camera, sometimes this helps remove that corrosion, setting things right again.
11/21/2010 5:16:35 PM • Canon IXUS i7... • Answered on Nov 21, 2010
How to restart canon ixus i7 digital camera
when i just touch the lens gently to remove the dirt then the lens cant retarct.and when i turned it on it says lens error restart the camera. pls help me
10/11/2010 1:56:33 AM • Canon IXUS i7... • Answered on Oct 11, 2010
Zoom error on fuji digital camera?
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/27/2010 5:23:00 PM • Canon IXUS i7... • Answered on Sep 27, 2010
Camera shutter not closing. saying
Hello
Regards
Andrea
9/17/2010 2:11:58 PM • Canon IXUS i7... • Answered on Sep 17, 2010
My ixus 8515 says "card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
8/31/2010 6:03:01 PM • Canon IXUS i7... • Answered on Aug 31, 2010
Card bloked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
8/30/2010 4:48:21 PM • Canon IXUS i7... • Answered on Aug 30, 2010
Need replacment charger docking station
7/13/2010 4:52:22 AM • Canon IXUS i7... • Answered on Jul 13, 2010
Hi, my canon ixus 8515 wont turn on, any ideas?
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
5/12/2010 1:15:43 PM • Canon IXUS i7... • Answered on May 12, 2010
I try to get my
It seems that the problem here is the connection of the camera and the computer, so what we can do here now is to connect the camera to a different USB port better if you connect it to the back USB port of your computer then power OFF the camera and wait till the computer recognize that its connected to it already.
Once the camera is detected by the computer you can now transfer files from camera to computer and vice-versa.
2/2/2010 12:29:27 PM • Canon IXUS i7... • Answered on Feb 02, 2010
2answers
Instruction Booklet
Hi you can get it here at the following website address
http://software.canon-europe.com/products/0010374.asp
Benjamin
1/21/2010 11:03:32 AM • Canon IXUS i7... • Answered on Jan 21, 2010
When i turn on my canon ixus i7 its say on the
this usually happens when lens are stuck, the reason for this is duct, could be the camera has dropped down, or the gears are jammed, now to make it work, while switching your camera on, try to tap very gently, near the lens, should make it shake in prior to make lens come out from jammed position, try this several times...it should work, if it does not, then take it to qualified service tech
10/28/2009 9:29:12 AM • Canon IXUS i7... • Answered on Oct 28, 2009
Picutres are not in focus when taken
Ups.. i think you have a serious problem. I don't know where the problem. But, maybe in your part of lens. There is any lens in front of the ccd. And I think it is not work properly. Try to assemble again. If you find your problem again..change your lens..I hope I right. Cause I never find this problem yet. For some problem i have post in my blog.Thanks
8/22/2009 3:39:18 PM • Canon IXUS i7... • Answered on Aug 22, 2009
Canon IXUS i7 Digital Camera Logo
29 questions posted
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
IXUS Canon
  • IXUS Canon
Most Popular Question
camera states screen card locked
  • Cameras
